Mesa 7i96s + VFD MODBUS HELP!
- egemens
- Visitor
04 Mar 2024 14:01 #295136
by egemens
Mesa 7i96s + VFD MODBUS HELP! was created by egemens
Hi all,
I just migrated from Mach3 to LinuxCNC. I am just a beginner in LinuxCNC.
I'm trying to use rs485 port on my mesa card to talk to my vfd/spindle.
I am following instructions from here:
linuxcnc.org/docs/2.9/html/drivers/mesa_modbus.html
i compiled the generic example mod file provided and try lo load it through my config.
I get an error: hm2: Cannot find PkgUART instance on hm2_7i96s.0.pktuart.0
How can i enable/install PkgUART? Do i need a custom firmware for my card?
- Thank you received: 5334
04 Mar 2024 14:43 #295140
Replied by PCW on topic Mesa 7i96s + VFD MODBUS HELP!
You would need to use 7I96S firmware that includes a PacketUART module,
7i96sd_pktv2.bin
Would be the suggested one
7i96sd_pktv2.bin
The following user(s) said Thank You: egemens
- egemens
- Visitor
04 Mar 2024 20:43 #295159
by egemens
Replied by egemens on topic Mesa 7i96s + VFD MODBUS HELP!
Also wanted to add this excellent video by talla83 explaining how to customize and compile the bin file. He adds new modules and make it available on the expansion port to use with jumper wires. Neat..
- egemens
- Visitor
19 Mar 2024 23:54 #296354
by egemens
First i managed to control to my spindle, but then it stopped working.
Things i have tried:
I checked cables and vfd, using another usb-rs485 converter, they have no problem
I tried hooking up a logic analyzer to the TX port, TB2 pins 18 and 19 on my 7i96s.
i am writing to coils and registers to the test pins i created but there seems to be no life on my port.
i reflashed the mesa card
mydevice.00.fault pin goes true as soon as i run the configuration and mydevice.00.last-error pin shows 11 (timeout)
But that was the situation with those pins before and i was able to control my spindle without problems.
Is there a way i can troubleshoot this?
I am afraid if i had toasted the port by connecting wrong terminals
20 Mar 2024 01:22 #296358
Can you try this script:
With the cabling that connects RX+ to TX+ and RX- to TX- (RS-485 connection)
with the proper bias resistors and report the results here
- egemens
- Visitor
20 Mar 2024 02:36 - 20 Mar 2024 02:46 #296365
by egemens
I took the card to home, so i cannot test on vfd, but somehow i guess i shall see some data on my logic analyzer. I'm no electronics expert but in the past i used it to troubleshoot some obscure modbus devices to make them work with Arduino.
it prints these in terminalsome user leds turn on some turn off
and the red light on my logic analyzer turns on (the codes absolutely make a difference)
If i go halrun and enter my config line by line
when i enter this line:
red light on the logic analyzer turns off
when i enter "start" command, screen fills with this (I think i enabled debug mode, that may be the reason)
and also if i run the gui instead of halrun, i get this error:
I still have zero action on the logic analyzer
i will have a look at the bias resistors and report again.
0000C3FF 000003FF 000043FFand the red light on my logic analyzer turns on (the codes absolutely make a difference)
loadrt hm2_eth board_ip="10.10.10.10" config="num_stepgens=3 sserial_port_0=0xxxxxxx"red light on the logic analyzer turns off
WAIT_FOR_DATA_FRAME - rxmode = 16200F8Eand also if i run the gui instead of halrun, i get this error:
Count > 1 invalid for function 6, resettingI still have zero action on the logic analyzer
Last edit: 20 Mar 2024 02:46 by egemens.
20 Mar 2024 03:15 - 20 Mar 2024 03:16 #296369
Means that the TX data is not echoed
on the RX data pin which does suggest
that the SP491 RS422/485 driver chip
is damaged (or there is a connection
issue since this test depends on the
TX --> RX loopback)
I would expect 06XXX at the end if the
RX pin followed the TX
0x8000 is the TXEN bit (active low)
0X4000 is the TX bit
0x2000 is the RX bit
Basically what the test does is clear
the I/O setup registers then enable
GPIO outputs on TX and TXen
(both will be low at first and low TXen means
enabled) then sets TX data high (0x4000)
to see if its echoed on RX (0x2000)
TX --> RX loopback)
Last edit: 20 Mar 2024 03:16 by PCW.
- egemens
- Visitor
20 Mar 2024 07:43 #296374
by egemens
the vfd i use has A and B connections only and i was using only Tx pins on the mesa card, since i was only sending frequency and turn spindle values.
As i understand from your message rx pins must be connected as well for the test to be successful
can you suggest a proper wiring diagram with resistors.
I know i am asking for much but it should be useful for other users as well
20 Mar 2024 15:08 #296389
7I96 TB2
15 GND --> 330 Ohm --> RX+
16 RX+ --> TX+
17 RX- --> TX-
18 TX+
19 TX-
20 5V --> 330 Ohm --> RX-
16 RX+ --> TX+
17 RX- --> TX-
18 TX+
19 TX-
- egemens
- Visitor
20 Mar 2024 15:47 #296392
by egemens
with the wiring you provided test commands print as follows:
0000E3FF
000003FF
000063FFPlease Log in or Create an account to join the conversation.
Time to create page: 0.227 seconds
