touch probe install
2 years 7 months ago #295544 by garja
touch probe install was created by garja
I'm progressing along with my setup with the help of this forum. I'm setting up a Chinese touch probe which has two stages. First stage triggers the tool height and the second stage works as an endstop. Despite the manual being in Chinese, I was able to get the probe working on pin 9 and selected "Probe In" for the pin. I've confirmed in Halshow that the NC is working properly. I can't find anything that gives me any step-by-step instructions as to what my next steps are. I've watched some YouTube videos where they show a touch_pate_ini and a touch_plate_hal but my pncconf wizzard did not create either of those two files? If I had those files, maybe, and I mean maybe I could follow the rest of the video and get my touch probe working. I've searched through the manuals installed with Linuxcnc and can't find anything there.
2 years 7 months ago #295565 by Wieser
Replied by Wieser on topic touch probe install
The names of the ini and hal files is not relevant. If you want to you can create a hal file named "touch_plate" and add it to the postgui_call_list.hal file.
Alternatively, you can just write it in your existing hal. I wrote it in the custom_postgui.hal, but I think it can be also written in your main hal file.
What you need is this pin: motion.probe-input
I connected my touch probe using a debounce. (not strictly necessary)
net Tastsignal hm2_5i25.0.7i77.0.0.input-00-not => debounce.0.0.in
net Taster_debounced debounce.0.0.out => motion.probe-input
This is used for my touch probe, but as far as I understand, linuxcnc has only one input for tool touch off probe and workpiece probe.
To use both you would use an or2 to route both inputs into the “motion.probe-input”
At least that’s what I will try, as I received the same tool probe with a Chinese manual yesterday.
2 years 7 months ago #295575 by garja
Replied by garja on topic touch probe install
Perfect! Thanks Wieser. Good luck with your probe.
2 years 7 months ago #296403 by garja
Were you able to connect your probe? I'm going to have to return mine and get a replacement. The emergency stop works when fully depressed but the tool sensing doesn't trigger. I'm wondering if you had 4 wires, red, black, green and yellow. Per the vendors instructions, the wires were to connect as follows:
Black: 24 volt positive
Green: Negative
Yellow: input pin for tool height
Red: Estop
If your wire colors match mine, I'd be interested to know if you used the same wiring the vendor provided.
Time to create page: 0.324 seconds
