Is EMC the software I need, or should I look for s
18 Nov 2010 11:03 #5397
Replied by andypugh on topic Re:Is EMC the software I need, or should I look for s
You seen to be pulling some of the p-port pins up to 12V, not 5V. I suspect that is not your intention.
It looks like you have already figured out that you need a 4-wire pattern, and that EMC2 can send 4-pin step patterns, see stepgen types 7, 8 and 10. www.linuxcnc.org/docview/html//man/man9/stepgen.9.html
18 Nov 2010 11:35 #5398
by Mihara
Replied by Mihara on topic Re:Is EMC the software I need, or should I look for s
andypugh wrote:
Yes, I got lost in all the connections when drawing it.
Thank you, you've helped me work this out a lot.
Time to create page: 0.350 seconds
