I wouldn’t bother with vendor supplied drivers.
They are really only for some of the manufacturer’s specific features of the chipset relating to the serial port.
From memory this card should be supported by parport_serial. The fact that there doesn’t seem to be a driver loaded is curious. I was wrong on this account whilst 1C00 does show up there is no entry for 1c00:2170, 1c00:3050 & 1c00:3250 are.
before we go too far have you established that the latency is adequate for software step generation ?
Have you tried the Parallel Port tester utility ? There are quite a few references to it in other threads dealing with Parallel Port issues. This topic usually comes up a few times a month. There’s a wealth of information on the forum but it seems the search function isn’t used.
What is still curious is that you haven’t supplied any error messages given by linuxcnc when starting a basic config. I’m pretty sure there is a supplied config for using a Parallel Port when running linuxcnc from the menu.
This maybe a solution, whilst the chipset is not the same it may just work.
www.linuxquestions.org/questions/linux-h...5657555/#post6018828
