paralel port do not worke
- maxzo
02 Apr 2024 08:44 #297424
by maxzo
paralel port do not worke was created by maxzo
Hi, I have installed LinuxCNC on my Lenovo ThinkCentre Edge 72 from 2012. The problem is that I can't get any response from the parallel port nor from "Axis" or the parallel port tester. I have no idea where to start.
- Thank you received: 426
02 Apr 2024 08:50 #297425
Replied by Cant do this anymore bye all on topic paralel port do not worke
If it's anything like a M72e you'll need a genuine Lenovo Parallel Port cable, otherwise it wont show up in the BIOS.
1. Does your parallel port appear if the BIOS settings (you'll have to look in the Lenovo manual for that)
2. try sudo dmesg | grep parport
The following user(s) said Thank You: maxzo
- maxzo
02 Apr 2024 14:01 #297434
by maxzo
Replied by maxzo on topic paralel port do not worke
thank you very much. It must be used with the original cable for this to work.
Time to create page: 0.188 seconds
