7i76e input output singals
03 Apr 2024 12:32 #297500 by Yannis
7i76e input output singals was created by Yannis
[url=https://www.facebook.com/groups/465128047350433/user/1186219141/?__cft__[0]=AZXp2iAvjPKVttWtEo_h-9s-ccv4qEPy6k0ub7zQ0ht-JGnU3HYOsg79OvJq67HNRT6-DUJ59gB9r1Zj5rZiXV_56ofNC1C82eUB0EDDl3ndsKjJ_Tp5gudk1G1rNiIKNMmi-e_liDLK-Z-ZlLnL-0ew&__tn__=-]K-R]Hello[/url] Im trying to setup a new pc on a existing machine with 7i76e. The output singals for the spindle and the Zaxis brake are working properly .The input singals for the limit switch are not working.What m i missing here? Following the ini and hal files
File Name: CMS_2024-04-03.hal
File Size:13 KB
File Name: CMS_2024-04-03.ini
File Size:5 KB
03 Apr 2024 13:16 - 03 Apr 2024 13:18 #297502 by PCW
Replied by PCW on topic 7i76e input output singals
The physical switch input signals names (home-x and both-x):
#--- HOME-X ---
net home-x <=> hm2_7i76e.0.7i76.0.0.input-05
net both-x <=> hm2_7i76e.0.7i76.0.0.input-04
do not match the names (or functions) connected to LinuxCNC's motion component:
# ---setup home / limit switch signals---
net x-home-sw => joint.0.home-sw-in
net x-neg-limit => joint.0.neg-lim-sw-in
net x-pos-limit => joint.0.pos-lim-sw-in
This is true for all joints.
Last edit: 03 Apr 2024 13:18 by PCW.
The following user(s) said Thank You: Yannis
04 Apr 2024 07:28 #297561 by Yannis
Replied by Yannis on topic 7i76e input output singals
In my old config i have connected all the driver fault with this
# --- ALL-LIMIT ---
net all-limit <= hm2_7i76e.0.7i76.0.0.input-11
to put the machine on estop when a driver failed
How can i do that in my new config?
04 Apr 2024 14:24 #297576 by PCW
net drive_fault    joint.0.amp-fault-in <= hm2_7i76e.0.7i76.0.0.input-11
or if you have free inputs:
net drive_fault_0    joint.0.amp-fault-in <= hm2_7i76e.0.7i76.0.0.input-11
net drive_fault_1    joint.1.amp-fault-in <= hm2_7i76e.0.7i76.0.0.input-12
net drive_fault_2    joint.1.amp-fault-in <= hm2_7i76e.0.7i76.0.0.input-13
Both will work(halt the machine on a a drive fault) , but the first won't
indicate which drive is at fault
05 Apr 2024 08:22 #297625 by Yannis
Also detect another bug
When i try to do RUN FROM HERE with right click the machine running the program from the beginning
Any suggestions
05 Apr 2024 09:55 #297634 by tommylight
Replied by tommylight on topic 7i76e input output singals
First left click on the line, then right click and run from here.
Time to create page: 0.179 seconds
