Phase Drive Questions
- Thank you received: 7461
07 Apr 2024 00:57 #297732
Replied by tommylight on topic Phase Drive Questions
Yes, of course, sorry i forgot about using two output pins.If you only have 2 output pins, and the drive is not step/dir
or CW/CCW, mode 2 is the only mode that makes sense...
- D-wilson357
07 Apr 2024 01:35 #297734
by D-wilson357
Replied by D-wilson357 on topic Phase Drive Questions
Removed Dropbox links and figured out how to resize my images and insert them, sorry about the nuisance.
I suspect the motion box thing is doing some sort of signal manipulation or filtering.
It seems bizarre to me there's a phase where there's no voltage output. I derive that from the working turbocnc setup I can plug this box into and it runs the stepper smoothly.
- Thank you received: 5308
07 Apr 2024 03:34 - 07 Apr 2024 03:34 #297738
Replied by PCW on topic Phase Drive Questions
There is always voltage applied to the motor,
but as I said, with 2 pins your only real choice
is mode 2.
The driver will create /PhaseA and /PhaseB
from the PhaseA and PhaseB parallel port
signals, so at any of the 4 possible output states
2 motor drive outputs are energized
is mode 2.
Last edit: 07 Apr 2024 03:34 by PCW.
- D-wilson357
08 Apr 2024 13:59 #297813
by D-wilson357
I think I've found part of the problem. With stepgen 2 I started checking the pin outputs in HAL-scope, and I seem to be getting quite a bit of phase drift on B. A behaves normally but B will run for extended periods and then miss others. once in a while it will synch correctly and run smoothly. I should've taken a screenshot to share. I'm guessing I have more latency then the test showed on this old laptop.
I'm gonna suspend testing this setup until the better PC I have on order shows up.
Thanks for the help guys!
Time to create page: 0.087 seconds
