Help conv_u32_bit
- Thayloreing
- Thank you received: 3
08 Apr 2024 20:34 #297832
by Thayloreing
Help conv_u32_bit was created by Thayloreing
I'm trying to convert a u32 output to a bit, I managed to load it in the hal, and I managed to monitor it in the showhalconfiguration, but I didn't find much information on how the converter works, I wanted any value above 0 the bit would be 1, I imagined that was it, However, when I set a value at the converter input, the output still remains at 0. Could you give me an explanation and, if possible, a solution to my problem? thanks in advance
- Thank you received: 5308
08 Apr 2024 21:39 - 08 Apr 2024 21:42 #297834
Replied by PCW on topic Help conv_u32_bit
Ack sorry there already is a u32-bit conversion
If it does not work, its possible the you did not addf
the conversion function to the servo thread:
addf conv_u32_bit.0 servo thread
Last edit: 08 Apr 2024 21:42 by PCW.
The following user(s) said Thank You: zz912, Thayloreing
- Thayloreing
09 Apr 2024 01:00 #297838
by Thayloreing
Replied by Thayloreing on topic Help conv_u32_bit
I actually forgot to add it to the service thread, thank you very much
