Issue on boot
- cncsparko
09 Apr 2024 13:52 #297864
by cncsparko
Issue on boot was created by cncsparko
Hi all,
Long story short before my time on a tempermanent repair a wire bender was run on linuxcnc but they liked it and kept it (ran 7yrs no issues)
CMOS battery died, shut down cleaned and replaced.
PC boots up fine but linuxcnc won't open.
I've attached a few images of what I get from it when trying to run and open it and the debug file.
apologies for the images, offline machine and no USB to hand (trying to get them to 21st century).
I'm very basic with linux but the messing around has inspired me to grab my raspberry pi and to get playing again (for one never thought to look for a linuxcnc OS)
- Thank you received: 426
09 Apr 2024 21:35 #297874
Replied by Cant do this anymore bye all on topic Issue on boot
Screen shots are difficult enough, but the debug section does not appear to be there, which kinda makes it hard.
- Thank you received: 7461
10 Apr 2024 00:40 #297881
Replied by tommylight on topic Issue on boot
Also this is not a boot issue, it is a LinuxCNC gracefully failing to start issue, gracefully as it also reports why it failed, but this time the reason it failed is missing from the pictures, we need the debug portion of the report, as Cornholio mentioned above.
- phillc54
- Thank you received: 2100
10 Apr 2024 03:14 #297891
by phillc54
Replied by phillc54 on topic Issue on boot
- cncsparko
10 Apr 2024 07:04 #297899
by cncsparko
Replied by cncsparko on topic Issue on boot
my apologies, thought I had that in the shot, I'll grab it off the machine. brought a drive with me so hoping to grab the data and drop it in a notepad
- cncsparko
10 Apr 2024 07:43 #297901
by cncsparko
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.5.0
Machine configuration directory is '/home/user/linuxcnc/configs/OMCG'
Machine configuration file is 'OMCG.ini'
INIFILE=/home/user/linuxcnc/configs/OMCG/OMCG.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Running HAL shutdown script
Killing task linuxcncsvr, PID=18670
Cleanup done
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/linuxcnc/hm2_pci.ko': -1 No such device
OMCG.hal:9: exit value: 1
OMCG.hal:9: insmod failed, returned -1
See the output of 'dmesg' for more information.
18670
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[78052.361444] I-pipe: Domain RTAI registered.
[78052.361457] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[78052.361463] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[78052.361535] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[78052.361541] PIPELINE layers:
[78052.361546] f8605e20 9ac15d93 RTAI 200
[78052.361552] c085cb20 0 Linux 100
[78052.387551] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[78052.387776] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[78052.387784] RTAI[sched]: hard timer type/freq = APIC/12468990(Hz); default timing: periodic; linear timed lists.
[78052.387790] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2793162000 hz.
[78052.387794] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[78052.388606] RTAI[usi]: enabled.
[78052.454124] RTAI[math]: loaded.
[78052.553392] hm2: loading Mesa HostMot2 driver version 0.15
[78052.557089] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[78052.926702] hm2: unloading
[78052.986193] RTAI[math]: unloaded.
[78053.035103] SCHED releases registered named ALIEN RTGLBH
[78053.064368] RTAI[malloc]: unloaded.
[78053.164026] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[78053.167983] I-pipe: Domain RTAI unregistered.
[78053.168077] RTAI[hal]: unmounted.
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.5.0
TASK=milltask
HALUI=halui
DISPLAY=axis
Cleanup done
18670
10 Apr 2024 09:15 #297903
I'd try reseating the Mesa card, and giving things a bit of a clean.
This is the error
This is the error
- cncsparko
10 Apr 2024 09:52 #297907
by cncsparko
Shut it down, removed the mesa card, gave it the ole cartridge clean and tried it.
No change.
Checked all the files and everything seems to be in the locations it's looking for, again amateur hour here but highly interested as stated.
No change.
- Thank you received: 4137
10 Apr 2024 09:55 #297909
Replied by rodw on topic Issue on boot
I think this file is missing:
what does this list?
sudo ls /usr/realtime-2.6.32-122-rtai/modules/linuxcnc/hm2_pci.ko
- cncsparko
10 Apr 2024 09:55 #297910
by cncsparko
Sorry for double message.
Got a red light on CR9 and CR10
And amber on CR11
On the card
Will drag up mesa manual see if that has anything that can contribute, probably the operating lights but need to start somewhere
And amber on CR11
On the card
Time to create page: 0.156 seconds
