PREEMPT_RT no longer needed in Ubuntu?
- vedatech
- Thank you received: 3
29 Apr 2024 00:54 #299284
by vedatech
PREEMPT_RT no longer needed in Ubuntu? was created by vedatech
I read somewhere that rt PREEMPT_RT kernel build was no longer needed in Ubuntu 23.10/24.04. Is this true? If so how do you access the real time features?
- Thank you received: 5308
29 Apr 2024 02:02 #299286
Replied by PCW on topic PREEMPT_RT no longer needed in Ubuntu?
It may not be not needed by Ubuntu, but its certainly needed by LinuxCNC...
The following user(s) said Thank You: Cant do this anymore bye all
- Thank you received: 426
29 Apr 2024 02:03 #299287
Replied by Cant do this anymore bye all on topic PREEMPT_RT no longer needed in Ubuntu?
Where did you read this ?
"I read somewhere that xxxx" often comes up but rarely is there a source.
- Thank you received: 4137
29 Apr 2024 05:07 #299293
I suspect that they use PREEMPT_DYNAMIC which is definitely not hard real time PREEMPT_RT
Replied by rodw on topic PREEMPT_RT no longer needed in Ubuntu?
- vedatech
29 Apr 2024 17:26 #299330
by vedatech
Replied by vedatech on topic PREEMPT_RT no longer needed in Ubuntu?
I'm using ubuntu 22.04.4 with the initrd.img-5.15.0-1061-realtime kernel (PREEMPT_RT)
and a Mesa 6i25 pci card.
I get very good jitter so I'll stick with that for now.
I'm running a RIP install of 2.9.0~pre and want to upgrade to 2.9.2 but don't want to loose the edits I've done in the RIP directory.
Any suggestions?
Any suggestions?
- Thank you received: 7461
29 Apr 2024 18:56 - 29 Apr 2024 23:48 #299335
Replied by tommylight on topic PREEMPT_RT no longer needed in Ubuntu?
Copy the configs directory to a USB stick, if there are no special components made by you in use, that is all you need.
Ubuntu does not use RT kernels anymore (no idea why), but you can safely use Debian RT kernels in Ubuntu, i know it worked for sure with 6.1 i think.
Edit:
got reminded below by PhillC about why Ubuntu has not RT kernel, they do but it is behind a paywall!
Edit:
Last edit: 29 Apr 2024 23:48 by tommylight. Reason: See above.
- vedatech
29 Apr 2024 19:32 #299338
by vedatech
I cloned what I though was 2.9.2 but VERSION says 2.10.0-pre0. It works but should I go back to 2.9.2 which is supposed to be stable. How do I get that version? Is there a branch name for it?
29 Apr 2024 20:23 #299342
Probably should say 2.9 instead of Master somewhere.
Sorry for the vague reply but was long ago.
- phillc54
- Thank you received: 2100
29 Apr 2024 23:43 #299359
by phillc54
Replied by phillc54 on topic PREEMPT_RT no longer needed in Ubuntu?
29 Apr 2024 23:46 #299360
Yup, but behind a paywall.
Time to create page: 0.551 seconds
