Foundational questions about my setup
- blazini36
- Thank you received: 167
03 May 2024 05:46 #299609
by blazini36
Replied by blazini36 on topic Foundational questions about my setup
I had similar issues with a small PC with Realtek NICs. In my case it was an early board revision and a bios update fixed it. Messing with the NIC drivers and everything else wasn't really helping. Can't say that a bios update would help in your case but you should definately see if something is available or see what bios settings are possible in regards to the NICs.
- Thank you received: 4153
03 May 2024 10:29 #299614
Replied by rodw on topic Foundational questions about my setup
Sorry about that. Very odd it did not work. Its been a while since i tried it.Small note for anyone in the future, the dkms driver actually made my latency worse and lcnc unusable. I guess I should always test.
following error and a read error almost instantly from hostmot2.
- Thank you received: 7496
03 May 2024 11:34 #299620
Replied by tommylight on topic Foundational questions about my setup
This is the second report of DKMS drivers making things worse, but there are much more reports of succes, so more research is needed.
Balzini makes a valid point about BIOS updates, a while back X570 boards had issues with USB that were fixed with BIOS update.
I made it a habit of updating BIOS on new boards, the amount of stuff that can go wrong in there is frankly staggering. F@ken Microsoft and UEFI....
Then again, having 50 bilion transistors on a 1x1cm space is astonishing!
- hachi
- Thank you received: 3
14 May 2024 23:27 #300631
by hachi
Replied by hachi on topic Foundational questions about my setup
I'll take a peek at firmware updates, but the machine is very stable with the in-tree nic driver, idle=poll, and a dedicated cpu for lcnc. All warnings have silenced and I can even record video from two cameras concurrently while lcnc is running with no latency issues.
15 May 2024 00:29 #300637
That is quite an improvement !
Time to create page: 0.190 seconds
