Step on-time step space
- FlaredFins
- Thank you received: 8
23 May 2024 14:52 #301207
by FlaredFins
Step on-time step space was created by FlaredFins
So I have a question to get me edumacated
So, I've seen a pile of questions related to Step on-time and Step space and it seems there's just a general rule of thumb for some numbers to put in as starting points. unfortunately, it drives my mind crazy. I would gander to think that every driver has a specific number for it but from looking at tech documents it is a bit hard to decipher especially when I don't really understand what it relates to (well somewhat understand). so, if I were to look at say documentation for the Gecko 201 because PNCconf has those settings already defined how would I pull that info out from the documentation or are those settings readily available because it's a drive that has been used more prominently?
I ask because I recently emailed the tech / support department at Stepper-Online and they had no idea what step on-time and step space were. found it rather odd that they would not know what info it was I was after. Their documentation doesn't seem to be lacking and appears to be about as detailed as say Gecko documentation.
- Thank you received: 7461
23 May 2024 15:40 #301219
Replied by tommylight on topic Step on-time step space
Pulse duration and time between pulses, that is step time and step space.
Or even longer explanation
Step time is how long a step signal should be in nano seconds
Step space is how long there should be no pulses, or the distance between the end of one pulse to the start of another pulse.
In general, start with 5000ns for both, despite what some drive info says, some drives will not work with to short pulses or might work but miss steps leading to dimensional issues in use.
I leave all but one machine at 5000, the one being a very fast one with expensive LAM Technologies drives, and even that runs at 3000ns despite working perfectly with much shorter timings.
There is absolutely no reason to use short timings if you do not have a really fast machine with very high microstepping.
If using prallel port that has limited capabilities then you can test shorter timings.
The following user(s) said Thank You: FlaredFins
- FlaredFins
23 May 2024 15:57 #301223
by FlaredFins
Replied by FlaredFins on topic Step on-time step space
So is there no way to pull info from the tech docs to get this information?
How would one know exactly how fine-tuned you can take a driver. I run the DM542T from stepper online my settings are
Step On-time 5000
Step Space 5000
Dir Hold 10000
Direction Setup 5000
These settings do seem to be fine for my setup as I don't believe I've had issues, but I've only run this new setup a few times for testing.
But if you look at the Gecko 201 it has settings of
Step On-time 500
Step Space 4000
Dir Hold 20000
Dir Setup 1000
Kind of a big difference and granted it might not be a fair comparison. But some of those settings go in different directions from what a base line setup would be. how would one come to the conclusion that I need to subtract 4500 from step on-time and bump Dir hold up another 10000.
Like I said my table seems to be running with no issues in traveling so I really don't need to make adjustments. I'm just curious.
Step On-time 5000
Step Space 5000
Dir Hold 10000
Step On-time 500
Step Space 4000
Dir Hold 20000
Dir Setup 1000
- FlaredFins
23 May 2024 16:04 #301225
by FlaredFins
- Thank you received: 2163
23 May 2024 16:08 #301226
Replied by Aciera on topic Step on-time step space
Yes
- FlaredFins
23 May 2024 16:46 #301228
by FlaredFins
So how do you take that info and translate it into Step On-time, step space dir hold and dir setup?
- Thank you received: 5308
23 May 2024 17:19 #301233
Replied by PCW on topic Step on-time step space
Step time = T3
Step space = T4
Dir setup = T2
Dir hold (missing from chart)
One really important thing to understand is that these are all _MINIMUM_
timings so unless you run into speed limitations, there is no reason to use
minimum values. In fact using minimum values increases the chance of problems
Step space = T4
Dir setup = T2
- FlaredFins
23 May 2024 18:09 #301237
by FlaredFins
Awesome that is what I was trying to understand. from what I've read, having these numbers off can lead to missed steps or no movement. Are there any other issues that would lead one to believe they have these numbers off?
Also, and of course in being curious PNCconf lists the gecko 201 with minimum values listed, in the dropdown choice, if I read the Gecko 201 doc correctly.
23 May 2024 18:24 #301239
Most common issue is too short step time, this can led to erratic
behaviour or no motion at all.
Too short direction setup or hold can result in lost or gained steps at reversals
but since reversals only happen at near 0 velocity (and consequent long times
between steps), there is little cost associated with setting quite long direction
setup and hold times (that is 20000 ns is probably OK for anything...)
23 May 2024 18:30 - 23 May 2024 18:31 #301240
"having these numbers off can lead to missed steps or no movement."
No, having these numbers too low can lead to missed steps or no movement.
Last edit: 23 May 2024 18:31 by PCW.
Time to create page: 0.452 seconds
