Step on-time step space
- FlaredFins
- Thank you received: 8
23 May 2024 18:34 #301242
by FlaredFins
Replied by FlaredFins on topic Step on-time step space
Awesome Thank you.
- FlaredFins
25 May 2024 14:18 #301412
by FlaredFins
So all this got me to digging a bit more which has lead to a few more questions. lol
In some reading i saw the same control signals when micro stepping is applied, and it appears the more micro stepping the more (chunky) the line becomes. Does micro stepping affect the step on-time and step space settings?
And kind of related, which is my current setup is set for 16 micro stepping and was set this way when I ran Mach 4 and I wound up going with that setting because my movements weren't smooth enough to maintain smooth cuts. granted I was in MACH4 but should I change to a different setting or am I fine leaving those drivers the way they are?
- Thank you received: 5308
25 May 2024 15:03 #301414
Replied by PCW on topic Step on-time step space
The micro step ratio does not affect the minimum timing
specifications, but a higher micro step ratio will require
a higher step rate to reach the same velocity. This higher step
rate (and the minimum timing requirements) may limit your
maximum velocity if you choose too high a micro step ratio.
In my experience, micro step ratios > 32 or so are not useful
as the magnetic aberrations in the step motor and current
control accuracy in the drive dominate the position accuracy
and torque ripple values at higher ratios.
Time to create page: 0.220 seconds
