I need help
23 May 2024 15:08 #301211 by Irritant
I need help was created by Irritant
Hi Guys
I am at a loss getting this thing to run. It is not a hobby for me I just need it to work. I am using a Probotix computer, Probotix controller and Probiotix black stepper motors. I have no need of limit switches, no home switches, ability to add later maybe. I need help, I can give the pitch of the feed screws. The table is about 25x25". Can anyone help me?
Thanks,
Ian
23 May 2024 15:42 #301220 by tommylight
Replied by tommylight on topic I need help
LOL at the nick name! :)
With the info you gave us, no, we can not help much, we need more info, what are the issues, pictures of the machine, specs, etc.
23 May 2024 15:54 #301222 by Aciera
Replied by Aciera on topic I need help
www.probotix.com/CNC-CONTROL-SYSTEMS/LinuxCNC-PC
Wow, 1200$ for a mini-ITX with 2Gb RAM, Ubuntu 10.04/LinuxCNC 2.6(!) and 2 ParallelPorts.
That is how you make money off of free and opensource software.
23 May 2024 17:09 #301231 by Irritant
Replied by Irritant on topic I need help
Can you give me a list of what is needed?
23 May 2024 17:37 #301235 by Aciera
Well, if you would tell us what you are trying to do then we could maybe help.
So, do you want/need to setup the PC with current software or what exactly is not working for you with the system you have got?
23 May 2024 19:06 #301246 by Irritant
I was running this on Linuxcnc and not sure what happened, and it was years ago now but it died on me. It started out made by Larken and going through a number of new steppers etc. The original machine was made about 2000. The machine is a 3 axis CNC Router. All the mechanics are in good shape and the machine has done a pile of work for me. I do all the CAD and CAM work myself. I cut everything from fiberglass to aluminium, wood and etc.
24 May 2024 06:59 #301289 by jimmyrig
Replied by jimmyrig on topic I need help
Does your PC boot?
Does your controller turn on?
Can they talk....Can you get any motion at all?
Where is it not working? You said mechanical is ok but nothing about electronics or software.
26 May 2024 15:48 #301490 by Irritant
The PC boots fine, the controller turns on (I hear the/a motors energise) I have no movement but the config files have not been configured, its an up to date Linux CNC.
26 May 2024 21:10 #301525 by jimmyrig
​​​​Ok
TAke a pic of your controller so we can point ya in the right direction.
If I had to guess try building the config with stepconf. You will need to know how your machine is wired.
27 May 2024 16:20 - 27 May 2024 16:21 #301597 by Irritant
I will get that off to you. Once it moves I will have better idea of what to change in the config files
Last edit: 27 May 2024 16:21 by Irritant. Reason: Short memory
Time to create page: 0.215 seconds
