I need help
2 years 5 months ago #301961 by Aciera
Replied by Aciera on topic I need help
use the 'StepConf' to setup your config and assign the pins according to this pinout:
www.probotix.com/wiki/index.php/Unity_Controller#Breakout_Board :
More information on the StepConf tool:
linuxcnc.org/docs/html/config/stepconf.html
As for setting up the motors, steppers usually have 200 steps per rev. According to the web page, your motor drives seem to be preset to 4x microstepping so 1 motor revolution would need 800 steps in addition to that you'll need to figure out the pitch of your lead screws to calculate the required number of steps to move the axis 1 machine unit (presumably 1 inch in your case.)
2 years 5 months ago #301969 by Aciera
I found a configurator script for Linuxcnc 2.6 here:
www.probotix.com/wiki/index.php/PROBOTIX...inuxCNC_Configurator
File Name: probotix.txt
File Size:41.51 KB
Note that this will not work for Linuxcnc 2.8 or above but the script attached below will give an idea of the settings needed for what you have.
For example the MondoStep drivers.
search the file above for 'mondostep' and you will find this:
        XYSCALE=$(expr "scale=4; 4*200*2/$I" | bc -l)         ZSCALE=$(expr "scale=4; 4*200*$ZTPI/$I" | bc -l)
which tells you that for x and y the scale should be 1600 steps per inch and for the z axis it's 800*TPI of the z leadscrew.
As for that you can then search for 'ztpi' and you will find this section from which you will glean more information about the max velocity:
case $ACME in     "ROTON" )         ZTPI=5         Z_MAXVEL=0.4         # 24IPM Z-Axis         ;;     "HELIX" )         ZTPI=2         Z_MAXVEL=2         # 120IPM Z-Axis         ;;
As for XY limits there is this section:
    "V90MK2" )         X_MAX_LIMIT=20.25         Y_MAX_LIMIT=12.4         UPRIGHT="SHORT"         ZBEARINGS=2         ;;     "GX2525" | "COMET" )         X_MAX_LIMIT=26.125         Y_MAX_LIMIT=25.1152         ;;     "GX2550" | "METEOR" )         X_MAX_LIMIT=26.125         Y_MAX_LIMIT=52.2         ;;     "GX3725" | "ASTEROID" )         X_MAX_LIMIT=37.25         Y_MAX_LIMIT=25.1152         ;;     "GX3750" | "NEBULA" | "METEORXL" )         X_MAX_LIMIT=37.25         Y_MAX_LIMIT=52.2         ;;     "GX5050" )         X_MAX_LIMIT=53.6         Y_MAX_LIMIT=51         UPRIGHT="TALL"         ZBEARINGS=4
Could be quite useful.
2 years 5 months ago #301971 by Aciera
also there is a basic ini file here which may give you an indication of what else you may need note in versions 2.8 and above the ini file has changed somewhat, eg all homing related values are in JOINT_n sections now:
# PROBOTIX ini file [EMC] MACHINE = REPLACE_MACHINE DEBUG = 0 [DISPLAY] #DISPLAY = axis DISPLAY = probotix-axis POSITION_OFFSET = RELATIVE POSITION_FEEDBACK = ACTUAL #POSITION_UNITS = INCH MAX_FEED_OVERRIDE = 1.0 MAX_SPINDLE_OVERRIDE = 1.0 DEFAULT_SPINDLE_SPEED = 8000 PROGRAM_PREFIX = /home/probotix/linuxcnc/nc_files INTRO_GRAPHIC = probotix_splash.gif INTRO_TIME = 5 INCREMENTS = REPLACE_INC OPEN_FILE = /home/probotix/linuxcnc/nc_files/PROBOTIX_logo_engrave.ngc EDITOR = gedit TOOL_EDITOR = tooledit PYVCP = pyvcp.xml #EMBED_TAB_NAME = Camera #EMBED_TAB_COMMAND = camview-emc -w {XID} [FILTER] PROGRAM_EXTENSION = .png,.gif Greyscale Depth Image png = image-to-gcode gif = image-to-gcode PROGRAM_EXTENSION = .py Python Script py = python PROGRAM_EXTENSION = .php PHP Script php = php PROGRAM_EXTENSION = .ngc2 Filtered NGC File ngc2 = g-code-filter.php PROGRAM_EXTENSION = .ngcl Laser NGC File ngcl = laser-filter.php [RS274NGC] PARAMETER_FILE = emc.var RS274NGC_STARTUP_CODE = REPLACE_RSC SUBROUTINE_PATH =  /home/probotix/linuxcnc/nc_files/subs USER_M_PATH = /home/probotix/linuxcnc/nc_files/mcodes [TASK] TASK = milltask CYCLE_TIME = 0.010 [EMCMOT] EMCMOT = motmod SHMEM_KEY = 111 COMM_TIMEOUT = 1.0 COMM_WAIT = 0.010 BASE_PERIOD = 100000 SERVO_PERIOD = 1000000 [HAL] HALFILE = probotix.hal POSTGUI_HALFILE = postgui.hal HALUI = halui CONTROLLER = REPLACE_CONTROLLER [HALUI] # add halui MDI commands here (max 64) MDI_COMMAND = o100 CALL [1]                                    (00) MDI_COMMAND = o102 CALL [2]                                    (01) MDI_COMMAND = G10 L20 P0 X0 Y0                                (02) MDI_COMMAND = G10 L20 P0 Z0                                    (03) MDI_COMMAND = G53 G0 XREPLACE_X_PARK Y0 Z0                    (04) MDI_COMMAND = G53 G0 XREPLACE_X_PARK YREPLACE_Y_PARK Z0        (05) MDI_COMMAND = G53 G0 X0 Y0 Z0                                (06) MDI_COMMAND = G0 X0 Y0                                        (07) MDI_COMMAND = REPLACE_RSC M6                                (08) MDI_COMMAND = M68 E00 Q0                                    (09) MDI_COMMAND = G10 L2 P0 X0 Y0 Z0                            (10) MDI_COMMAND = G64 P0.010                                    (11) MDI_COMMAND    = M68 E0 Q100                                    (12) MDI_COMMAND    = o103 CALL                                        (13) [USER_COMMANDS] NUMBERKEYS = TRUE USER0 = USER1 = USER2 = USER3 = USER4 = USER5 = USER6 = USER7 = USER8 = USER9 = [TRAJ] AXES = REPLACE_AXES COORDINATES = REPLACE_COORDINATES LINEAR_UNITS = REPLACE_UNITS ANGULAR_UNITS = degree CYCLE_TIME = 0.010 DEFAULT_VELOCITY = REPLACE_DEFAULT_VELOCITY DEFAULT_ANGULAR_VELOCITY = 1440 MAX_LINEAR_VELOCITY = REPLACE_MAX_LINEAR_VELOCITY MAX_ANGULAR_VELOCITY = 1440 NO_FORCE_HOMING = 0 [EMCIO] EMCIO = io CYCLE_TIME = 0.100 TOOL_TABLE = tool.tbl [AXIS_0] TYPE = LINEAR HOME = 0 MAX_VELOCITY = REPLACE_XY_MAXVEL MAX_ACCELERATION = REPLACE_XY_MAXACCEL STEPGEN_MAXACCEL = REPLACE_XY_STEPGEN_MAXACCEL SCALE = REPLACE_XY_SCALE FERROR = REPLACE_FERROR MIN_FERROR = REPLACE_MIN_FERROR MIN_LIMIT = -REPLACE_XY_MIN_LIMIT MAX_LIMIT = REPLACE_X_MAX_LIMIT HOME_OFFSET = -REPLACE_XY_HOME_OFFSET HOME_SEARCH_VEL = -REPLACE_XY_SEARCH_VEL HOME_LATCH_VEL = -REPLACE_XY_LATCH_VEL HOME_IGNORE_LIMITS = 1 HOME_SEQUENCE = 1 #HOME_FINAL_VEL = 3.0 [AXIS_1] TYPE = LINEAR HOME = 0 MAX_VELOCITY = REPLACE_XY_MAXVEL MAX_ACCELERATION = REPLACE_XY_MAXACCEL STEPGEN_MAXACCEL = REPLACE_XY_STEPGEN_MAXACCEL SCALE = REPLACE_XY_SCALE FERROR = REPLACE_FERROR MIN_FERROR = REPLACE_MIN_FERROR MIN_LIMIT = -REPLACE_XY_MIN_LIMIT MAX_LIMIT = REPLACE_Y_MAX_LIMIT HOME_OFFSET = -REPLACE_XY_HOME_OFFSET HOME_SEARCH_VEL = -REPLACE_XY_SEARCH_VEL HOME_LATCH_VEL = -REPLACE_XY_LATCH_VEL HOME_IGNORE_LIMITS = 1 HOME_SEQUENCE = 1 #HOME_FINAL_VEL = 3.0 [AXIS_2] TYPE = LINEAR HOME = 0 MAX_VELOCITY = REPLACE_Z_MAXVEL MAX_ACCELERATION = REPLACE_Z_MAXACCEL STEPGEN_MAXACCEL = REPLACE_Z_STEPGEN_MAXACCEL SCALE = REPLACE_Z_SCALE FERROR = REPLACE_FERROR MIN_FERROR = REPLACE_MIN_FERROR MIN_LIMIT = -REPLACE_Z_MIN_LIMIT MAX_LIMIT = REPLACE_Z_MAX_LIMIT HOME_OFFSET = REPLACE_Z_HOME_OFFSET HOME_SEARCH_VEL = REPLACE_Z_SEARCH_VEL HOME_LATCH_VEL = REPLACE_Z_LATCH_VEL HOME_IGNORE_LIMITS = 1 HOME_SEQUENCE = 0 [AXIS_3] TYPE = ANGULAR HOME = 0 MAX_VELOCITY = 1440 MAX_ACCELERATION = 4000 STEPGEN_MAXACCEL = 5000 SCALE = 6.6666 FERROR = 5 MIN_FERROR = 1 HOME_IGNORE_LIMITS = 1 HOME_SEQUENCE = 1
2 years 4 months ago #302534 by Irritant
Replied by Irritant on topic I need help
Hi, I have it moving using the stepconfig test buttons. It will also move clicking on the jog buttons. I have figured out how to load a G file. Biggest problem right now is that it won't run a G code file, at least I don't know how to do it. I need some help with this. Spelling out the basics is what I need right now.
Thanks all, Ian
2 years 4 months ago - 2 years 4 months ago #302544 by Aciera
In AXIS GUI click on the blue triangle in the tool bar or select 'Run program' from the 'Machine' menu.
[edit]
This is rather dated but might be worth having a look:
Last edit: 2 years 4 months ago by Aciera.
2 years 4 months ago #302647 by Irritant
I am in Ottawa Canada, a bit of a drive.
