Trouble Shooting USB Jogging with an Xbox Controller
2 years 5 months ago #301368 by RyanB
I've been having some issues in getting a wired Xbox360 controller working with LinuxCNC and could use some words of wisdom.
I've set up the controller in the Pncconf wizard:
I've ran the configuration in LinuxCNC but pressing the relevant controllers yields no result. However the meter does show the expected signals:
Any suggestions on what I am missing?
2 years 5 months ago #301370 by cmorley
is the machine homed?
2 years 5 months ago #301372 by RyanB
I haven't added limit switches yet, that's further down the line.
2 years 5 months ago #301374 by cmorley
Pncconf probably didn't get updated to set up unhomed joint jogging for the joystick.
So it must be homed before jogging works.
You don't need limit switches to home.
2 years 5 months ago #301436 by RyanB
Is there a way to disable that requirement?
2 years 5 months ago #301457 by cmorley
Sure. Can you post your config files.
You could also home an axis/the machine and try the joystick to see if that is actually the problem.
Time to create page: 0.097 seconds
