Trying out LinuxCNC on Raspberry PI5
26 May 2024 15:05 #301518 by mbennett
Trying out LinuxCNC on Raspberry PI5 was created by mbennett
I setup a Raspberry PI5 using this download:
26 May 2024 18:20 #301535 by Grotius
Replied by Grotius on topic Trying out LinuxCNC on Raspberry PI5
What's the easiest interface board for a new user to use
Parport bob is easy to use.
There are guides to set it up.
  • Platinum Member
  • Platinum Member
27 May 2024 04:49 #301554 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic Trying out LinuxCNC on Raspberry PI5
Unless the BoB provides 3.3 <> 5.0v translation you're gunna have a bad day.
I don't think there are any sim configs for the RPi, most config will need post config.
This may help you out....there is another user trying this out, juest recently
byte2bot.com/products/parallel-port-raspberry-pi-hat
forum.linuxcnc.org/9-installing-linuxcnc...i-5?start=180#297833
Then after that it's either DIY or Mesa.
27 May 2024 07:39 #301573 by mbennett
Replied by mbennett on topic Trying out LinuxCNC on Raspberry PI5
I tried the byte2bot board. Couldn't get it to work. Requires alteration of the HAL file that i don't understand. I'm looking for a combination of board and setup that doesn't require any changes to the HAL file. Will a Mesa board do that? If so which one and which setup?
  • Platinum Member
  • Platinum Member
27 May 2024 10:33 #301595 by Cant do this anymore bye all
Well mate ya gunna be well outta luck.
It you want the easiest option a PC with a parallel port will just about get you there.
Or you can ask for help with the board you have.
Even a Mesa card will require you to at least have the firmware you require and setting of an IP address on the Ethernet side. There's no SPI support for the RPi5, despite what the blurb says. Trust me I think I've wasted money getting a Rpi5 for Linuxcnc.
To use the GPIO a driver has to be load and setup correctly. I don't even know if Linuxcnc supports a GPIO to serial adapter or what you mean. JT has a config tool for that floating around. Andy Pugh has the low down on how it works.
The thing is there are that many machines and combinations at at the least you ave to use at PCconf for mesa or stepconf for a parallel port setup for a PC.
We'll help but you'll have to put some effort in. If you don't want to put the effort in that's your loss.
But for a 2 axis milling machine and the level of effort you want to put in grbl might be a better option for you.
27 May 2024 18:33 #301625 by cakeslob
Replied by cakeslob on topic Trying out LinuxCNC on Raspberry PI5
your best bet is a mesa ethernet card or get an RPi4
Im sure your configuration issue isnt anything that difficult. Im sure the company, or other users could help you to figure it out. It is also beneficial long term to try and learn the HAL
Most setups require you to do something,, but a mesa ethernet board you can use the config program, or a flexihal ethernet thing comes without changing the config but you need to load new firmware probably
or contact byte2byte to ask them for assistance
But also for anyone else interested, this fellow in the Other Languages section, has made some kind of RPi GPIO config tool
forum.linuxcnc.org/37-international-linu...-cnc-software#286005
23 Mar 2025 10:23 #324671 by looping
Replied by looping on topic Trying out LinuxCNC on Raspberry PI5
Is it possible to use the Master version on a Pi5 ?
23 Mar 2025 22:31 #324724 by rodw
Replied by rodw on topic Trying out LinuxCNC on Raspberry PI5
It isn't supported out of the box but you could build it from source. I made a video
24 Mar 2025 01:21 #324729 by elovalvo
Replied by elovalvo on topic Trying out LinuxCNC on Raspberry PI5
www.instructables.com/LinuxCNC-on-Raspbe...Pi-With-GPIO-Control
24 Mar 2025 03:11 #324732 by looping
@rodw excellent ! I couldn't spot any differences from x64 build
Time to create page: 0.354 seconds
