Setting up linuxcnc
27 May 2024 09:36 #301553 by yathish
Setting up linuxcnc was created by yathish
Hi, this is Yathish.
I'm trying to run a small Stepper Motor 42SHDC3025-24B using A4988 driver (just one axis). I'm finding it hard to set this up. I'm using raspberry pi 4 with  as my os.
I'm finding it hard to go further. Whichever resources I refer online is of no use.
Can anyone please help me out with the steps to proceed?
  • Platinum Member
  • Platinum Member
27 May 2024 09:50 #301555 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic Setting up linuxcnc
What have you been trying ?
27 May 2024 12:26 #301569 by yathish
Replied by yathish on topic Setting up linuxcnc
I want to run the motor which I have mentioned earlier
28 May 2024 05:06 #301640 by yathish
I want to control stepper motor using linuxcnc, using a4988 driver. IS it possible?
  • Platinum Member
  • Platinum Member
28 May 2024 10:23 #301653 by Cant do this anymore bye all
Linuxcnc can control any kind of driver that accepts step & direction inputs.
28 May 2024 11:11 #301658 by andypugh
Replied by andypugh on topic Setting up linuxcnc
Start with the stepconf wizard and pretend that you have a parallel port.
Then you will need to edit the HAL file, removing everything that says "parport" and replacing it with a Pi GPIO pin instead.
Use this driver: linuxcnc.org/docs/stable/html/drivers/hal_gpio.html
06 Jun 2024 04:34 #302432 by yathish
Thankyou Andy, It worked !
Do you know how to control motors using G-codes?
24 Jun 2024 08:34 #303675 by yathish
Thankyou for helping me out. Now I want to use 7 inch display instead of monitor. How to do it. Can I create my own UI like adding logo and changing color of the UI.
Is this possible?. If yes gve me steps to it
Time to create page: 0.266 seconds
