Reconnect to Mesa ethernet card
  • egemens
  • egemens's Avatar Topic Author
  • Visitor
  • Visitor
28 May 2024 07:01 #301644 by egemens
Reconnect to Mesa ethernet card was created by egemens
Hi, I was curious if there is a way to reconnect to mesa card without restarting linuxCNC. Sometimes i turn my cnc machine off without quitting linuxCNC. It throws a hm2read error as it has lost the connection. But i cannot establish connection without restarting linuxcnc.
I've tried entering initialization line on my main hal file going "hm2_eth board_ip= ......."
also mesaflash with --reload argument
28 May 2024 10:49 #301656 by andypugh
Replied by andypugh on topic Reconnect to Mesa ethernet card
You can try "unload hostmot2" and then reloading it. But I think you would then then need to reload the specific card driver and re-make all the HAL connections.
28 May 2024 13:45 #301676 by PCW
Replied by PCW on topic Reconnect to Mesa ethernet card
Can you keep the Ethernet card powered? This will still likely require
re-homing if the drives have been powered down,
It is possible to re-connect to the card after a read error but I don't think
you can get things setup properly without  basically relaunching LinuxCNC
so the hal file drivers are reloaded and all initial parameters are re-setup.
19 Jul 2024 12:03 - 19 Jul 2024 13:12 #305645 by nutsowl
Replied by nutsowl on topic Reconnect to Mesa ethernet card
Hi, what about restart linuxcnc without reboot gui? Any idea about this?
Any ideas on how to do this?
The way I envision it: First we start the glade file with the mesa-board connection indicator and the “power” button. Clicking the button starts linuxuxcnc config.ini and activates a nested glade container with the control interface.
I have a very superficial understanding this, but I really want to find information to implement the above, please help!
Last edit: 19 Jul 2024 13:12 by nutsowl.
19 Jul 2024 13:13 #305647 by PCW
Seems like it would be a lot easier to just keep the interface card powered
we are only talking a few watts here...
  • Platinum Member
  • Platinum Member
19 Jul 2024 14:50 #305655 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic Reconnect to Mesa ethernet card
I have separate power controls for PC, MESA, Steppers & Spindle, if I'm going to be a away for a bit I just turn the Stepper & Spindle power off. And the way I have the relays that control the contactors if the mains goes & comes back on nothing energizes. To an outsider it may seem I have too many separate power supplies.
Time to create page: 0.956 seconds
