7i78 power
05 Jun 2024 16:08 #302389 by rajsekhar
7i78 power was created by rajsekhar
I have a system 7i92+ 7i76 (on P2 connector of 7i92) +7i84 (connected to RS422 of 7i76).
I am using separate (not FPGA) 5V power for 7i76 TB3 pin 21,22 (W2 in right position).
Now, I want to add one 7i78 (on P1 connector of 7i92).
If I do not use FPGA power, how to power the 7i78?
05 Jun 2024 16:14 #302390 by PCW
Replied by PCW on topic 7i78 power
You can power the 7I78 via one of the step/dir connections,
but typically the 7I78 draws such little current (<100 ma) that
it makesĀ  mores sense to power it via the FPGA cable.
05 Jun 2024 17:44 #302402 by rajsekhar
Replied by rajsekhar on topic 7i78 power
That mean 5v and ground pin of any step/dir to be connected?
05 Jun 2024 18:04 #302403 by PCW
Yes, that will work (but it's easier to just power it from the FPGA card)
Time to create page: 0.230 seconds
