Absolute homing
2 years 4 months ago - 2 years 4 months ago #303124 by rodw
Replied by rodw on topic Absolute homing
I commited the PR to conform with the standerd pin names which should make it easier for you to try this component. It needs testing!
Last edit: 2 years 4 months ago by rodw.
2 years 4 months ago #303129 by rodw
I have checked my code and we are not doing it either!
I've added an issue to remind me to fix this.
I am out of time now until this evening.
Happy to accept a PR to correct this in the meantime.
The following user(s) said Thank You: tommylight, Aciera
2 years 4 months ago #303147 by Aciera
Replied by Aciera on topic Absolute homing
I suggest we move the discussion about Ethercat drive homing over to the other thread, as we are starting to run things in parallel here:
forum.linuxcnc.org/ethercat/52968-help-n...c-servo-homing-setup
The following user(s) said Thank You: tommylight, besriworld
2 years 4 months ago #303190 by besriworld
Replied by besriworld on topic Absolute homing
This homing is for absolute encoder (single turn)?
For servo motors with multi-turn absolute encoder linuxcnc just takes current shaft position ?
Time to create page: 0.289 seconds
