How to config a lathe-mill machine with Linuxcnc ?
- timaer
- Thank you received: 4
22 Jun 2024 09:21 - 22 Jun 2024 09:27 #303544
by timaer
How to config a lathe-mill machine with Linuxcnc ? was created by timaer
Hi,everyone ,we are developing a new machine with Linuxcnc,but met some problem now . the biggest problem now is that our machine can both lathe and mill .I'm a newbee to Linuxcnc .I only know how to config a traditional lathe or a traditinal mill machine now with ini and hal file,but I dont know how to config a machine mixed them together .Suppose my workmates used Fusion360 export a complete G-code program to me .and the G-code at least include, S command for spindle while lathe,and X,Z command for axis movement ,then there will also a C command for rotate while milling . So,if our machine has 3 servo motors(using Etherecat to connect and control the servo motor), first and second one for X,Z axis move,and the third one will be as both spindle and rotate axis C .I dont know how to config the ini and hal .Does anyone here be kind enough to share the ini and hal configuration using linuxcnc to achive such requirment ? I'll be very grateful for that ,thanks.
Last edit: 22 Jun 2024 09:27 by timaer.
- Thank you received: 2163
22 Jun 2024 13:39 #303555
Replied by Aciera on topic How to config a lathe-mill machine with Linuxcnc ?
Maybe have a look here:
forum.linuxcnc.org/10-advanced-configura...ling?start=50#288345
The following user(s) said Thank You: timaer
- timaer
24 Jun 2024 01:40 #303659
by timaer
Replied by timaer on topic How to config a lathe-mill machine with Linuxcnc ?
Thank you so much ,Aciera. It's a very useful link,really helpful
Time to create page: 0.288 seconds
