How to dynamically switch one ethercat servo motor from spindle to axis ?
03 Jul 2024 20:52 - 04 Jul 2024 04:03 #304352 by timaer
Hi,everyone,I've configured an ethercat controlled servo motor as a spindle with hal,and I was able to config it as a angular axis too .But ,now the demand is to switch it from spindle then the A angular axis dynamically,I dont know how to achive this.I've read about sample code in linuxcnc called millturn,but a little complicated.The problem seems that if there is a way to dynamically switch from a spindle to joint or joint to spindle in hal.I read about cia402 comp doc ,saying it's not possible for security reason.So,I dont know ,what is the best solution for a turn-mill or mill-turn machine.Because it need using one servo motor as both a spindle and an axis.I've added my hal in the attachment .Could anyone give me some advice how to make it in linuxcnc ? Thanks.
Last edit: 04 Jul 2024 04:03 by timaer.
07 Jul 2024 12:25 #304587 by andypugh
If the spindle is controlled with velocity commands then it may be just a case of switching to a position PID (which still outputs velocity commands)
wiki.linuxcnc.org/cgi-bin/wiki.pl?SpindleOrient
The following user(s) said Thank You: timaer
07 Jul 2024 20:28 #304620 by timaer
Thank you ,andy. I'm using a servo motor as the spindle,and it is controlled by linuxcnc-ethercat.I dont know if it is satisfied for the condition to use the Orient component.I 've read the link you provided,but the final output seems to be VFD,is it compatiable with ethercat's control mode ? In fact ,I only want the servo motor to be acted as both spindle and c-axis,it can run the G-Code ,such like M3 S1000 for spindle ,and also G0 C100 for axis move. I dont know if using Orient component is the solution for it ,hope to recv more info to done it in linuxcnc.
07 Jul 2024 23:36 #304630 by Aciera
Possible solutions will depend on the hardware you are running, so you might want to ask this question in the EtherCAT section.
08 Jul 2024 00:08 #304634 by timaer
Thanks.I'll post a question in Ethercat section then.BTW,if without considering the hardware condition,what will be the best solution for my requirement? To buy a PWM or VFD motor and using Orient component ?
08 Jul 2024 02:54 - 08 Jul 2024 02:59 #304641 by Aciera
I wouldn't use a VFD for a C-axis. A VFD might be able to orient well enough for a tool changer but the dynamics and precision of a rotary axis are much higher and a servo motor would certainly be my choice.
There is also a video in german:
forum.linuxcnc.org/10-advanced-configura...able-issues?start=20
I have successfully used a servo motor for this in an experimental setup. In that case I dynamically switched between step/dir position command for rotary and analog (0..10V) for spindle velocity. A modified orient component and M19 command was used to rehome the spindle when switching from spindle to rotary mode. In the end the problem was that my servo motor setup was not stiff enough in rotary mode and the motor brake had too much play when engaged.
[edit]
I gather that traditionally there is a motor with belt drive for the spindle mode and a different motor on a worm gear that is mechanically engaged for the rotary mode. Although I would be somewhat surprised if that was still the case on modern machines.
Last edit: 08 Jul 2024 02:59 by Aciera.
08 Jul 2024 03:09 #304644 by timaer
Thank you ,Aciera.In fact I also want to use servo motor
to be acted as both spindle and axis too. The below youtube link
is the final result I want to achive,though the sample hal config in the comment ,I found a little too complex for me :(
08 Jul 2024 03:18 #304646 by timaer
Hi,I'v watched your youtube video.It looks that the most of the solution need to use Mesa board.but I'm now using Raspberry pi ,so do I have to buy a Mesa board for achiving the spindle / axis as one functionality?
08 Jul 2024 03:20 #304647 by Aciera
Also a bit dated, a fair bit has changed since. Although setting up the spindle orientation is certainly still not the easiest thing to do.
08 Jul 2024 03:34 #304650 by timaer
Yes,I quite agree with that. I think both the spindle orientation or the spindle/c-axis for mill-turn functionality are commonly used .It's better to make it easier for using it in linuxcnc.Maybe the developer or the community of linuxcnc should consider to simplify it for the common user.
Time to create page: 0.514 seconds
