halcmd: loadrt hostmot2
Note: Using POSIX realtime
halcmd: loadrt hm2_eth board_ip="192.168.1.121" config="num_encoders=0 num_pwmgens=0 num_stepgens=-1 num_dplls=0"
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 192.168.1.121: INFO: Hardware address (MAC): 00:60:1b:11:81:84
hm2_eth: discovered 7I92T
hm2/hm2_7i92.0: Low Level init 0.15
hm2/hm2_7i92.0: 34 I/O Pins used:
hm2/hm2_7i92.0: IO Pin 000 (P2-01): IOPort
hm2/hm2_7i92.0: IO Pin 001 (P2-14): IOPort
hm2/hm2_7i92.0: IO Pin 002 (P2-02): StepGen #0, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 003 (P2-15): IOPort
hm2/hm2_7i92.0: IO Pin 004 (P2-03): StepGen #0, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 005 (P2-16): StepGen #4, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 006 (P2-04): StepGen #1, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 007 (P2-17): IOPort
hm2/hm2_7i92.0: IO Pin 008 (P2-05): StepGen #1, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 009 (P2-06): StepGen #2, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 010 (P2-07): StepGen #2, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 011 (P2-08): StepGen #3, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 012 (P2-09): StepGen #3, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 013 (P2-10): IOPort
hm2/hm2_7i92.0: IO Pin 014 (P2-11): IOPort
hm2/hm2_7i92.0: IO Pin 015 (P2-12): IOPort
hm2/hm2_7i92.0: IO Pin 016 (P2-13): IOPort
hm2/hm2_7i92.0: IO Pin 017 (P1-01): IOPort
hm2/hm2_7i92.0: IO Pin 018 (P1-14): IOPort
hm2/hm2_7i92.0: IO Pin 019 (P1-02): StepGen #5, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 020 (P1-15): IOPort
hm2/hm2_7i92.0: IO Pin 021 (P1-03): StepGen #5, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 022 (P1-16): StepGen #9, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 023 (P1-04): StepGen #6, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 024 (P1-17): IOPort
hm2/hm2_7i92.0: IO Pin 025 (P1-05): StepGen #6, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 026 (P1-06): StepGen #7, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 027 (P1-07): StepGen #7, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 028 (P1-08): StepGen #8, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 029 (P1-09): StepGen #8, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 030 (P1-10): IOPort
hm2/hm2_7i92.0: IO Pin 031 (P1-11): IOPort
hm2/hm2_7i92.0: IO Pin 032 (P1-12): IOPort
hm2/hm2_7i92.0: IO Pin 033 (P1-13): IOPort
hm2/hm2_7i92.0: registered
Why StepGen #4, pin Direction (Output) and StepGen #9, pin Direction (Output) are not assigned?
