Linuxcnc xyz jitter when ide
- danielb744
08 Jul 2024 16:00 #304672
by danielb744
Linuxcnc xyz jitter when ide was created by danielb744
Hello everyone, I'm new to linuxcnc. I testing a new setup with stepper motors and mesa7i96s, it is working fine but at idle the xyz starts jittering even after homing the axis. This cause a vibration on the stepper motors. Obviously my stepper motors don't feedback the position to Mesa controller hence I don't understand why this is happening. Attach a 3 second video to show the issue
Grateful if you could shed some light on this.
- smc.collins
- Thank you received: 139
12 Jul 2024 23:28 #305039
by smc.collins
Replied by smc.collins on topic Linuxcnc xyz jitter when ide
typically jitter on steppers is due to electrical noise leaking in to the step/dir lines
- Thank you received: 426
13 Jul 2024 01:23 #305041
Replied by Cant do this anymore bye all on topic Linuxcnc xyz jitter when ide
Whilst that could be a possibility the noise would need enough strength to drive the optocoupler in most stepper drivers. Unless there is an awful lot of noise.
I think (and I maybe wrong) PID numbers can still have an affect in open loop configs, here's a brief discussion
forum.linuxcnc.org/38-general-linuxcnc-q...loop-steppers#119303
- Thank you received: 5308
13 Jul 2024 02:34 #305044
Replied by PCW on topic Linuxcnc xyz jitter when ide
Yes, too high a P term in the local feedback loop can do this.
For Mesa hardware P should be 1/servo_thread_period
so 1000 for a 1 ms (1000000 ns) servo thread period
or 500 for a 2 ms period.
Time to create page: 0.327 seconds
