G71 canned roughing D value - Is this a bug?
- cadcam
- Thank you received: 7
18 Jul 2024 12:03 - 18 Jul 2024 12:14 #305570
by cadcam
G71 canned roughing D value - Is this a bug? was created by cadcam
Linux 2.9.3 and any D greater than 0 will cause a "G7X error: Cannot intersect parallel lines". With a D0 value it will function perfectly.
Any Gurus who have an idea what the problem is would be appreciated. Code attached.
ThanksĀ
ThanksĀ
Last edit: 18 Jul 2024 12:14 by cadcam.
- mark-v-d
18 Jul 2024 21:12 - 18 Jul 2024 21:20 #305597
by mark-v-d
Replied by mark-v-d on topic G71 canned roughing D value - Is this a bug?
Yes it's a bug. It should be fixed in 2.9.4.
For now you can "fix" this by removing the "N45 X32". line
Or make the X equal to the starting position so "N45 X33"
Last edit: 18 Jul 2024 21:20 by mark-v-d. Reason: Additional info
The following user(s) said Thank You: cadcam
- cadcam
19 Jul 2024 05:08 #305608
by cadcam
Replied by cadcam on topic G71 canned roughing D value - Is this a bug?
Champion! Thanks.
Time to create page: 0.120 seconds
