Lag in MPG response after updating from 2.7 to 2.9
- robforbes
- Thank you received: 5
18 Jul 2024 15:41 #305578
by robforbes
Hi all,
After updating my system from 2.7 to 2.9 I am experiencing a lag when changing directions with my MPG wheel. It is like there is a short period of time (maybe 1/4 second) after changing direction (e.g. +X to -X) when linuxcnc is ignoring the MPG pulses. Otherwise, everything seems to be working fine as it did before the update. Does anyone know if 2.9 has any settings that might cause (or fix) this?
The HAL file is attached. I'm following up with the pendant manufacturer as well, but it looks like they just made changes for the joint/axis separation in 2.8.
updated version LinuxCNC 2.9.3 Debian 12 Bookworm PREEMPT-RT ISO
Vista cnc M1 USB pendant
Atom 525MW motherboard
Mesanet 5i25 PCI board--using its parallel port
Thanks,
Rob
Lag in MPG response after updating from 2.7 to 2.9 was created by robforbes
Hi all,
Thanks,
Rob
- Thank you received: 4648
21 Jul 2024 11:20 #305776
Replied by andypugh on topic Lag in MPG response after updating from 2.7 to 2.9
Is this just velocity jogging ? (there is an option to stop the axis when the wheel stops, even if the axis is not in position yet. ) Though I don't think that has changed.
A lot related to the names of joint and axis pins changed between 2.7 and 2.9, possibly the conversion script missed something.
- robforbes
21 Jul 2024 17:47 #305801
by robforbes
Replied by robforbes on topic Lag in MPG response after updating from 2.7 to 2.9
I have been using individual step jogging
Rob
Rob
Time to create page: 0.534 seconds
