I don't know if the overtravel I'm observing is actually an issue, that's why I asked in the first place. If someone can confirm that the order of operations performed by LinuxCNC is as I understand them to be, it should not be an issue after all.Correct statement. The spindle requires indexing at 0deg before the probe tool be mounted and meas takes place. And ofc only effective in the angles the calibration is prog to be within. Best 'workaround' I found to address this delay/overtravel issue. Yet.
After successful probing, parameters 5061 to 5069 will be set to the coordinates of X, Y, Z, A, B, C, U, V, W of the location of the controlled point at the time the probe changed state.
Depends on your Servo Thread, usually 1ms for a Mesa setup.(every thread cycle; 25us by default?)
Thank you! I somehow missed (or forgot reading) the docs...Over travel in G38.x does not influence the stored position, it would be fairly useless if it did:
Yeah. I just found out that I mixed the times of the servo and base threads in my headDepends on your Servo Thread, usually 1ms for a Mesa setup.
Doesn't this mean that x-output has 2 writers?net x-output <= pid.x.output
net x-output <= hm2_7i92.0.stepgen.00.velocity-cmd
