Hello,
i just set upo mey new pc with linuxcnc. Everything seems to work correctlly, except the keyboard. From time to time suddenly the keybiadr does not longer work. I can still use the mouse to navigate, this problem ist not only under linuxcnc itself, it affects also all other applications under linux. When i reboot everything is fine again for a while. I already tested multiple keyboards and usb ports.
i could not reproduce the problem, it coms when it has the desire for it.
to be sure its not because of the power supplies for the stepper drivers, i switched them comletely off
perhaps its a problem with the rt kernel, but i could not found something about that there are only people who have problem with the keyboard under linuxcnc but the other applications are noit effected
my configuration: microatx board with intel i5, 16GB ram, onboard graphics pcix parallel portcard und parallel bob with 4 attached axis - latest linuxcnc iso image is used
Georg
