Help installing samba on Debian 12 Bookworm PREEMPT-RT ISO
- Dave2024
- Thank you received: 10
28 Jul 2024 18:37 #306261
by Dave2024
Help installing samba on Debian 12 Bookworm PREEMPT-RT ISO was created by Dave2024
Hey sorry im not all that good with Linux but was wondering is someone could help me figure out how to add the a repository to make it so I can install samba server onto the LinuxCNC Debian 12 build? See ive done it in the past using other versions of Linux and even knew how to add repositories in other versions like Ubunto but now that im constantly switching versions of Linux ive kinda gave up on learning because the commands and file locations are always changing. My end goal is to be able to have samba running on my cnc mills interface computer so that im able to simply transfer gcode files over wifi from my modeling and posting machine that runs windows. Ive gotrten tired of having to constantly move files on a micro usb and have to walk from the shop back into the modeling room every time I go to run an operation. Anyways how can I get the samba repository added so I can run the 'sudo apt install samba' command and not get the
E: Package 'samba' has no installation candidate error? Thanks
- Thank you received: 4150
28 Jul 2024 18:43 #306264
Replied by rodw on topic Help installing samba on Debian 12 Bookworm PREEMPT-RT ISO
It is there packages.debian.org/search?keywords=samb...bookworm§ion=all
Do you have internet connection?
Once you sort that out, be aware that Windows needs come policy changes to allow Samba
The following user(s) said Thank You: Dave2024
- Thank you received: 426
28 Jul 2024 23:02 - 28 Jul 2024 23:05 #306292
Replied by Cant do this anymore bye all on topic Help installing samba on Debian 12 Bookworm PREEMPT-RT ISO
I find it far easier to connect directly from the Debian file manager to a windows share, no need to setup a samba server. All is required is to have the gvfs packages installed.
Or use the file sharing that is part of a lot of wifi AP\Routers, use that as an intermediary drop off point.
Last edit: 28 Jul 2024 23:05 by Cant do this anymore bye all.
- Dave2024
29 Jul 2024 06:12 #306307
by Dave2024
Ok well I think I found the repository list on LinuxCNC Debian 12 Bookworm. Its located in /etc/apt/sources.list or at least i think thats it? When I look at min using nano it shows deb cdrom:[Debian GNU/Linux 12 _Bookworm_ - Snapshot amd64 LIVE/INSTALL Binary 20240307-23:28]/ bookworm contrib main non-free non-free-firmware
Am I suppose to add packages.debian.org/search?keywords=samb...bookworm§ion=all to it?
And yes have internet access. Im actualy using SSH rite now working on it from my girlfriends place 15 miles away
Replied by Dave2024 on topic Help installing samba on Debian 12 Bookworm PREEMPT-RT ISO
29 Jul 2024 08:11 #306313
Nooo, that page says its part of Debian so nothing to do in the apt foders
Can you try
sudo apt update
Can you try
sudo apt update
- Dave2024
30 Jul 2024 01:26 #306373
by Dave2024
It installs just finew when using the ISO from the Debian site but when using the Debian 12 Bookworm PREEMPT-RT ISO from Linuxcnc.org its a no go
Yeah thats how I usually install it except when using the Debian 12 Bookworm PREEMPT-RT ISO found on the site here on the linuxcnc.org/downloads/ page it doesnt work and gives me the error: E: Package 'samba' has no installation candidate.Nooo, that page says its part of Debian so nothing to do in the apt foders
Can you try
sudo apt update
30 Jul 2024 08:32 #306386
That sounds very odd, because we use the Debian 12 live installer so it is just Debian with some added elements for Linuxcnc.
Time to create page: 0.949 seconds
