Inch display on Metric machine?
- MartynT
29 Jul 2024 11:33 #306320
by MartynT
Inch display on Metric machine? was created by MartynT
Although I read a few discussions related to this sort of question I haven't been able to find a definitive answer to my situation (i.e. not a real problem).
So, my machine is set up as metric and if I draw in a particular Inventor project in inches the g-code generated dictates inches through G20. Everything runs fine and the parts are spot on as you would expect. Now, I don't always want to go to the trouble of making a drawing and code for some simple actions where I just jog the mill over an item. This actually still works kind of OK but the display shows MM and I have to convert the inches I'm working to into metric each time, which is a bit of a PITA.
Is there a simple way I can start LCNC up and get an inch or mm display without having to convert all the machine specs (even if that was possible) in the Pncconf wizard? I also have a .hal file for the jog pendant which should be relatively easy to modify for inch movement.
Excuses if this has been answered before. Any input gratefully received.
Regards,
Martyn
Regards,
Martyn
- scotth
- Thank you received: 62
29 Jul 2024 15:22 #306337
by scotth
Replied by scotth on topic Inch display on Metric machine?
In AXIS use the VIEW tab and select Inch or Metric display, or use the "!" key.
The following user(s) said Thank You: MartynT
- MartynT
29 Jul 2024 16:05 #306341
by MartynT
Replied by MartynT on topic Inch display on Metric machine?
- MartynT
29 Jul 2024 20:13 #306360
by MartynT
Well I just looked at the solution and although it does show inches the Manual Control (F3) is still working in mm’s, and of course so is the pendant. So it actually makes the situation more confusing.
Come to think of it I had actually noticed this choice under View before.
Time to create page: 0.101 seconds
