I found old PC in the dumpster with parallel port
  • PhilipME
  • PhilipME's Avatar Topic Author
  • Elite Member
  • Elite Member
03 Aug 2024 08:39 #306835 by PhilipME
I installed linuxcnc and checked the latency.
It scored 12 million nano second
back to dumpster
03 Aug 2024 11:53 #306840 by tommylight
Replied by tommylight on topic I found old PC in the dumpster with parallel port
Not yet, there are things ti disable in BIOS, like hyperthreading, power saving, TPM, sleep states, turbo mode, speed step, etc.
And get the older Wheezy ISO as it uses the RTAI kernel and test with it, should do much better.
Also, repasting the CPU cooler will often make the PC usable.
The following user(s) said Thank You: PhilipME
  • PhilipME
  • Elite Member
  • Elite Member
03 Aug 2024 17:20 #306870 by PhilipME
Not sure how to do all that, but I will read
thanks
  • PhilipME
  • Elite Member
  • Elite Member
08 Aug 2024 11:55 - 08 Aug 2024 11:57 #307258 by PhilipME
Many thanks
I wanted to follow your recommendation, entered the bios . Could not find anything related to hyper threading.
I really dont know what I did as there are many settings, but after I reboot, the base thread latency running about less than 20000 ns
coming down from 12 million. Never thought it is possible.
It is better than my other device.
It is difficult to find a computer that is powerful enough and has a parallel port.
I really appreciate your support to the users
Last edit: 08 Aug 2024 11:57 by PhilipME.
08 Aug 2024 13:31 #307261 by tommylight
That might very well be usable, so start one of the included parallel port configurations and leave it running for a while, see if it shows latency warnings.
  • PhilipME
  • Elite Member
  • Elite Member
09 Aug 2024 04:06 #307286 by PhilipME
I will start another topic as the issue now is different
Many thanks
Time to create page: 0.218 seconds
