G53, and G54
- PhilipME
- Thank you received: 14
06 Aug 2024 14:22 #307089
by PhilipME
G53, and G54 was created by PhilipME
Is there is a way to save G53, and G54 after turning the machine off?
- Thank you received: 2163
06 Aug 2024 14:35 #307092
Replied by Aciera on topic G53, and G54
G53 is your machine reference point that is set during homing.
G54 .. g59 should be saved when you exit linuxcnc. At least that is what happens on my installations.
The following user(s) said Thank You: PhilipME
- PhilipME
06 Aug 2024 15:29 - 06 Aug 2024 15:36 #307102
by PhilipME
Replied by PhilipME on topic G53, and G54
I dont have homing (I bought the limit switches but did not install them yet )
So every start I have to zero x,y,z and that will be my G53 every time.
What I am doing now is G53 G0 x0 y0 then I shut the machine
next start I will set x, y to zero again to set g53 again. For some reason G54 is saved. But it is useless if G53 is lost.
Philip
Edit :
apology
I just realized that my question has no meaning.
I have to install the limit swiches, be able to home, then G54 will work because it is saved.
Philip
Edit :
apology
Last edit: 06 Aug 2024 15:36 by PhilipME.
Time to create page: 0.142 seconds
