Not sure if my parallel port is working
  • PhilipME
  • PhilipME's Avatar Topic Author
  • Elite Member
  • Elite Member
09 Aug 2024 04:14 #307287 by PhilipME
Not sure if my parallel port is working was created by PhilipME
In another computer,  I usually hear the clicking of the relay in my bob when I click to start the cooling water pump
but in this computer I am not sure if the parallel port is working.
this is what I get from dmesg > boot.txt
10.473367] lp: driver loaded but no devices found
[   10.542907] ppdev: user-space parallel port driver
[   10.653516] parport_pc 00:06: reported by Plug and Play ACPI
[   10.653592] parport0: PC-style at 0x378, irq 5 [PCSPP,TRISTATE]
[   10.756442] lp0: using parport0 (interrupt-driven).
[   12.327487] input: PC Speaker as /devices/platform/pcspkr/input/input10
[   12.567250] at24 0-0050: supply vcc not found, using dummy regulator
[   12.569898] at24 0-0050: 256 byte spd EEPROM, read-only
[   12.725210] sd 2:0:0:0: Attached scsi generic sg0 type 0
[   12.725268] sr 3:0:0:0: Attached scsi generic sg1 type 5
[   12.880444] RAPL PMU: API unit is 2^-32 Joules, 3 fixed counters, 163840 ms
Good day
Philip
  • Platinum Member
  • Platinum Member
09 Aug 2024 04:35 #307288 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic Not sure if my parallel port is working
The parallel port is there 0x378
Have you tried running your machine ?
The following user(s) said Thank You: PhilipME
  • PhilipME
  • Elite Member
  • Elite Member
09 Aug 2024 05:50 #307289 by PhilipME
Replied by PhilipME on topic Not sure if my parallel port is working
No I did not try to run anything because the bob is not connected to anything yet.
I will try to run a small motor
Thank you for the reply
  • PhilipME
  • Elite Member
  • Elite Member
09 Aug 2024 09:53 #307322 by PhilipME
You are right it is working
Time to create page: 0.770 seconds
