Question regarding limit and home switch config
- arijitdutta
- Thank you received: 3
12 Aug 2024 03:32 - 12 Aug 2024 03:33 #307511
by arijitdutta
Question regarding limit and home switch config was created by arijitdutta
Hi all,
I have two NPN NO proximity sensors hooked up on my lathe on input 1,2 in my 7i96s. In the Pncconf wizard, when I am trying to put the 'limit and home shared' on the respective axis and home them together, both axis are moving towards the sensors, then as soon as the one axis reaches the home switch, both the axis starts the homing sequence without the other getting at the home position and then it shows "limit joint 0/1 error". But when I am changing the inputs from 'limit and home shared' to 'home', the homing sequence works properly and it behaves just like a shared limit-home switch.
Since the proper input should be the shared limit-home, is there something that I am doing wrong or am I missing something?
Last edit: 12 Aug 2024 03:33 by arijitdutta.
- Online
- Thank you received: 7466
12 Aug 2024 11:51 - 12 Aug 2024 11:52 #307538
Replied by tommylight on topic Question regarding limit and home switch config
Not near a PC, but do not chose shared switches, that means shared between axis/joints, choose ... i can not recal what exactly, but it has a lot of choices so choose min or max limit with home for the respective axis/joint, or both min/max and home, if the switches are set up for that.
Last edit: 12 Aug 2024 11:52 by tommylight.
The following user(s) said Thank You: arijitdutta
- arijitdutta
12 Aug 2024 15:14 #307549
by arijitdutta
Replied by arijitdutta on topic Question regarding limit and home switch config
Thank you, that helps..
Time to create page: 0.233 seconds
