Cannot build 2.9.3, get "different exception specifier"
- CNC_Tinkerer
16 Aug 2024 00:08 #307852
by CNC_Tinkerer
Cannot build 2.9.3, get "different exception specifier" was created by CNC_Tinkerer
I upgraded to Debian 12 and LinuxCNC v2.9.3 and find I can no longer build.
Linux debian2 6.1.0-22-rt-amd64 #1 SMP PREEMPT_RT Debian 6.1.94-1 (2024-06-21) x86_64 GNU/Linux
Downloaded 2.9.3 tarball from git yesterday.
I kept pretty good notes on building with 2.8.x and can't find anything I previously encountered related to this. I can Make just my own code but when I do the full Make I get the following:
I'd appreciate if someone could suggest how to proceed. This doesn't seem to involve any code under my control.
user1@debian2:~/linuxcnc-dev/src$ make
Reading 54/210 dependency files
Done reading dependencies
Reading 0/238 realtime dependency files
Done reading realtime dependencies
cp ../scripts/rtapi.conf ../tests/uspace/spawnv-root/rtapi.conf
Compiling rtapi/uspace_rtai.cc
In file included from rtapi/uspace_rtai.cc:10:
/usr/include/x86_64-linux-gnu/sys/io.h:38:12: error: declaration of ‘int iopl(int) noexcept’ has a different exception specifier
38 | extern int iopl (int __level) __THROW;
In file included from /usr/include/rtai/rtai_lxrt.h:522,
from rtapi/uspace_rtai.cc:6:
/usr/include/rtai/asm/rtai_lxrt.h:170:38: note: from previous declaration ‘int iopl(int)’
170 | #define rtai_iopl() do { extern int iopl(int); iopl(3); } while (0)
/usr/include/rtai/rtai_lxrt.h:605:9: note: in expansion of macro ‘rtai_iopl’
605 | rtai_iopl();
make: *** [Makefile:288: objects/rtapi/uspace_rtai.o] Error 1I'd appreciate if someone could suggest how to proceed. This doesn't seem to involve any code under my control.
- CNC_Tinkerer
16 Aug 2024 00:55 #307858
by CNC_Tinkerer
Replied by CNC_Tinkerer on topic Cannot build 2.9.3, get "different exception specifier"
Looks like I had conflicts because I needed to remove
linux-image-4.19.0.9-rt-amd64
Now it builds as expected.
I thought I followed the upgrade instructions exactly, but either I missed that step or they did not mention it.
- Thank you received: 7488
16 Aug 2024 01:10 #307861
Replied by tommylight on topic Cannot build 2.9.3, get "different exception specifier"
You actually upgraded an existing Debian 10 installation to Debian 12 ?
I thought it was a new install, despite the statement, sorry.
Personally, i never ever upgrade existing installations since Ubuntu 10.04 to 11.04, it failed miserably, so i never bothered, i just do a clean install, much faster and does not come with baggage!
The following user(s) said Thank You: Cant do this anymore bye all
Time to create page: 0.157 seconds
