TeraTerm like program for LinuxCNC
19 Aug 2024 19:53 #308164 by slowpoke
TeraTerm like program for LinuxCNC was created by slowpoke
What terminal program (similar to say TeraTerm) is best to use with LinuxCNC (Axis)?
I'm debugging a board that has a UART -> FTDI USB dongle that is sending debug information, and I want to view the information while running Axis.
The UART data is being sent at 115200, however I can slow it down if need be.
I imagine there is a Linux command to determine what port has been assigned to the FTDI dongle when I plug it in?
19 Aug 2024 19:56 #308165 by tommylight
Replied by tommylight on topic TeraTerm like program for LinuxCNC
lsusb
and
ls /dev/tty*
The following user(s) said Thank You: slowpoke
  • Platinum Member
  • Platinum Member
19 Aug 2024 22:55 #308172 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic TeraTerm like program for LinuxCNC
Gtkterm is rather good general purpose GUI terminal program. Tho a lot simple and less detailed interface.
  • Platinum Member
  • Platinum Member
19 Aug 2024 22:59 #308173 by Cant do this anymore bye all
To find the port to device mapping, the last couple of entries in demsg will have what you need.
You may also want to look at a udev rule so the device has the same entry under /dev. Google persistent naming for ftdi device or something similar.
Time to create page: 0.107 seconds
