how to recompile a linuxcnc directory?
- Thayloreing
- Thank you received: 3
21 Aug 2024 15:27 #308302
by Thayloreing
how to recompile a linuxcnc directory? was created by Thayloreing
Hello my friends, I made some changes to create some pins in the halui.cc file that I acquired on github, but I have no idea how to recompile it so that the changes are children, could anyone help me? Maybe give a step-by-step guide on how I can recompile. thank you in advance
- Thank you received: 2176
21 Aug 2024 17:10 #308320
Replied by Aciera on topic how to recompile a linuxcnc directory?
If you want to modify the source code you would need to clone the source code and build linuxcnc locally on your machine (called a 'Run In Place' or 'RIP' installation):
linuxcnc.org/docs/master/html/code/building-linuxcnc.html
- Thayloreing
21 Aug 2024 18:24 #308329
by Thayloreing
Replied by Thayloreing on topic how to recompile a linuxcnc directory?
and there is no way to just compile this file? just building Linuxcnc from scratch? I'm not very experienced with this, I thought maybe it wouldn't even compile a component, but apparently it's more complicated than I imagined it would be.
21 Aug 2024 18:41 #308332
I'm not a expert but to compile this file it needs to link all the #includes so I don't see how that would work without the source code.
In any case doing a RIP installation is not really such a big deal. I work pretty much exclusively with locally built installations, getting all the required build dependencies can be a bit tedious but once you've got past that it's really quite simple.
- Thank you received: 4151
22 Aug 2024 00:14 #308352
Replied by rodw on topic how to recompile a linuxcnc directory?
The build system should just build what you have changed.
- Thayloreing
22 Aug 2024 01:21 #308357
by Thayloreing
I'm going to study the manual, but I've never done it, I'll probably have several questions as I go along, I ask you to be patient with me, but I thank you for taking the time to answer
- mighty_mick
- Thank you received: 5
23 Aug 2024 14:56 - 23 Aug 2024 15:01 #308467
by mighty_mick
Replied by mighty_mick on topic how to recompile a linuxcnc directory?
There are rules in files named 'Makefile'. You can consider to learn how make works. To compile only halui, just do these steps below:
1. Go to your project directory
2. Go to src directory located in your porject root directory
3. run this: make ../bin/halui
You can compile only halui.cc with these steps. But before doing it, be sure you already configured the source tree.
halui executable is being outputted at bin directory in your project root directory. This is why you are should run ../bin/halui rule in Makefile located in your src directory. You can build many single executables with this combination. If you wanna learn what does the Makefile include, just do these:
1. type this to your shell in src directory: make
2. After typing 'make', press space to give space character
3. Press TAB two times.
It is gonna show the rules. You can build axis, mdi, milltask, halui, iocontrol etc. in the same way.
Last edit: 23 Aug 2024 15:01 by mighty_mick.
The following user(s) said Thank You: Thayloreing
Time to create page: 0.123 seconds
