how to recompile a linuxcnc directory?
2 years 2 months ago #308302 by Thayloreing
Hello my friends, I made some changes to create some pins in the halui.cc file that I acquired on github, but I have no idea how to recompile it so that the changes are children, could anyone help me? Maybe give a step-by-step guide on how I can recompile. thank you in advance
2 years 2 months ago #308320 by Aciera
If you want to modify the source code you would need to clone the source code and build linuxcnc locally on your machine (called a 'Run In Place' or 'RIP' installation):
linuxcnc.org/docs/master/html/code/building-linuxcnc.html
2 years 2 months ago #308329 by Thayloreing
and there is no way to just compile this file? just building Linuxcnc from scratch? I'm not very experienced with this, I thought maybe it wouldn't even compile a component, but apparently it's more complicated than I imagined it would be.
2 years 2 months ago #308332 by Aciera
I'm not a expert but to compile this file it needs to link all the #includes so I don't see how that would work without the source code.
In any case doing a RIP installation is not really such a big deal. I work pretty much exclusively with locally built installations, getting all the required build dependencies can be a bit tedious but once you've got past that it's really quite simple.
2 years 2 months ago #308352 by rodw
The build system should just build what you have changed.
2 years 2 months ago #308357 by Thayloreing
I'm going to study the manual, but I've never done it, I'll probably have several questions as I go along, I ask you to be patient with me, but I thank you for taking the time to answer
Time to create page: 0.316 seconds
