Raspberry pi 5 password
31 Aug 2024 15:52 #309097 by Moutomation
Raspberry pi 5 password was created by Moutomation
I use Raspery on Pi5, there are no problems, it starts automatically without a password when the first power comes on. While the CNC is running and processing materials, a password login screen appears occasionally, but the CNC does not stop and continues to work. What causes this encrypted login screen to appear?
03 Sep 2024 13:00 #309283 by andypugh
Replied by andypugh on topic Raspberry pi 5 password
Are you using the supplied LinuxCNC RPi image? If so it sounds like we might need to fix something in the setup. A CNC machine shouldn't screen-blank.
There is a whole thread about screen blanking here: forums.raspberrypi.com/viewtopic.php?p=433728#p433728
(Basically there are several things that can blank the screen)
If it locks the system, requiring a password, then it won't be the always-tricksy "dpms"
03 Sep 2024 18:28 #309301 by Moutomation
Replied by Moutomation on topic Raspberry pi 5 password
I am using the image shared by rodw. The problem does not persist now, I have solved it. If you want, I can share pictures of how I did it tomorrow.
Time to create page: 0.070 seconds
