Inspect current G64 parameters?
  • JetForMe
  • JetForMe's Avatar Topic Author
  • Elite Member
  • Elite Member
02 Sep 2024 21:09 - 02 Sep 2024 21:09 #309228 by JetForMe
Inspect current G64 parameters? was created by JetForMe
Is there a way to see what the current G64 configuration is? e.g what values of P and Q are? Are there some system-defined parameters that hold these values?
It shows in the status line as `G64`, does that mean it’s G64 by itself, with no P or Q specified? (This is the problem with the absence of some indication in the UI leading to ambiguous interpretation.)
Last edit: 02 Sep 2024 21:09 by JetForMe.
03 Sep 2024 04:44 #309257 by cmorley
Replied by cmorley on topic Inspect current G64 parameters?
It's available in python as attribute 'settings'.
linuxcnc.org/docs/devel/html/config/pyth...xcnc_stat_attributes
You can also see it by using linuxcnc status program.
The following user(s) said Thank You: JetForMe
Time to create page: 0.165 seconds
