Probe Basic / Touch Probe
- crazycajun
10 Sep 2024 21:21 #309864
by crazycajun
Probe Basic / Touch Probe was created by crazycajun
when i try to open probe basic it crashes before fully loading and gives an error.
can gmoccapy use the probe or does it have to be in probe basic?
i have it wired to a input and selected as probe in the config but it the only pid i found in hal show never triggers. the probe light isnt green either, so i may have two issues.
- Unlogic
- Thank you received: 128
11 Sep 2024 05:38 #309880
by Unlogic
Replied by Unlogic on topic Probe Basic / Touch Probe
According to the log your graphics card is the reason why Probe Basic doesn't start.
Probe Basic requires a OpenGL 3.2 and pixel shader 1.5 capable graphics card.2024-09-10 16:14:08.613 ( 5.246s) [ A8C6040] vtkShaderProgram.cxx:438 ERR| vtkShaderProgram (0x86b5790): 0:1(10): error: GLSL 1.50 is not supported. Supported versions are: 1.10, 1.20, and 1.00 ES
/usr/bin/linuxcnc: line 974: 4169 Segmentation fault $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
4132
4165
Stopping realtime threads
Unloading hal components
Note: Using POSIX realtime
4132
4165
- crazycajun
11 Sep 2024 11:39 #309895
by crazycajun
Replied by crazycajun on topic Probe Basic / Touch Probe
So the integrated graphics arent good enough?
- Thank you received: 7488
11 Sep 2024 13:21 #309901
Replied by tommylight on topic Probe Basic / Touch Probe
Yes it is.
The issue seems to be you have a new Linux/GLSL driver with an older version of VTK.
- crazycajun
11 Sep 2024 13:45 #309903
by crazycajun
how do i fix that?
- Unlogic
11 Sep 2024 14:14 #309906
by Unlogic
It depends on which integrated graphics you have, they come in many different varieties.So the integrated graphics arent good enough?
- crazycajun
11 Sep 2024 14:41 #309908
by crazycajun
this is what dell has listed under the drivers: Intel G31/G33/Q33/Q35 Graphics Controller, v.7.15.10.1472, A00
i cant seem to find much since its so old. inspiron 545s, E5300 cpu.
- Unlogic
11 Sep 2024 14:52 #309909
by Unlogic
That's Core 2 Duo/Quad era hardware.
Unfortunately the built in graphics in those chipsets don't support the required pixel shader version. So a separate graphics card needs to be installed.
I found that out myself last winter while CNC converting my mill...
- crazycajun
11 Sep 2024 15:02 #309912
by crazycajun
Well, i got a couple spare cards that should work. I ordered a case because the Inspiron has a slim and Nothing fits LOL
- crazycajun
15 Sep 2024 19:09 #310216
by crazycajun
ok, card is in, screen resolution set properly, probe basic opens, i hit estop and start, but i get no movement out of any axis. gmoccapy works fine. ideas?
Time to create page: 0.183 seconds
