Probe Basic / Touch Probe
15 Sep 2024 19:25 #310219 by Unlogic
Replied by Unlogic on topic Probe Basic / Touch Probe
Is the machine homed?
Unlike Axis you can't jog the machine in Probe Basic unless it has been homed first.
15 Sep 2024 19:52 #310221 by crazycajun
Replied by crazycajun on topic Probe Basic / Touch Probe
it wasnt, i homed it in gmoccapy and probe basic still had no movement. i read there are files to copy and then hand edit. my brain started smoking while reading all of it so i had to stop.
15 Sep 2024 19:54 #310222 by Unlogic
It's no too bad actually. I started with a working AXIS configuration and created my Probe Basic config from that following the instructions available in the sticky thread here on the forum.
16 Sep 2024 17:27 #310275 by Lcvette
Replied by Lcvette on topic Probe Basic / Touch Probe
the sim should work without any modification to the config files, if so then everything is installed correctly, just compare your config files for your machine config to the sim config files. there are a few sections in the ini file that are required for probe basic and they stand out easily enough and then there are some additional files in the sim config that you won't find in the axis config folder that will need to be copied over. its not too bad and its good to become familiar with these files as they are there for user integrations and customizations in probe basic.
19 Sep 2024 13:12 #310452 by Lcvette
i just updated the documentation for probe basic it now coveres several key areas including installation (of several methods), machine configuration building and setup, including making an easy to copy over file bundle placed in the config folder during installation, and an easy to follow guide on editing the ini and hal files. it will be much easier to keep current as the forum was difficult to edit or make changes to without utterly destroying the original formatting of the post. all doc updates will be directly on the probe basic website now and will be maintained and update with any major releases.
kcjengr.github.io/probe_basic/index.html
The following user(s) said Thank You: JohnnyCNC, crazycajun, Unlogic
19 Sep 2024 13:42 #310454 by Unlogic
Big thanks Lcvette!
I think that guide will much appreciated by people setting up Probe Basic for the first time.
The following user(s) said Thank You: Lcvette
Time to create page: 0.540 seconds
