Running Gcode Program with G54 without any tool offsets
- upplib
16 Sep 2024 23:41 #310284
by upplib
Running Gcode Program with G54 without any tool offsets was created by upplib
New to Linuxcnc, got my Mesa 7i96 working and able to run Gcode on my DIY CNC without doing any cutting. The Gode was generated from Fusion 360 with Origin on the TOP Left Corner of the Part. When i used Mach3, all i do move the tool to the Origin on the part manually and Set G54 offset. Then program runs. Will this be the Same in LinuxCNC or it will automatically load some tool offsets from File. When I tried a to run the program after setting the G54 on TOP-LEFT-CORNER of the part, it moves up in Z and ask me to load a tool. When press enter it runs the program.
Thanks.
Thanks.
- Thank you received: 4150
17 Sep 2024 10:31 #310299
Replied by rodw on topic Running Gcode Program with G54 without any tool offsets
What gui? sounds like you have enabled a manual tool change for premeasured tools.
- Thank you received: 7488
17 Sep 2024 10:50 #310302
Replied by tommylight on topic Running Gcode Program with G54 without any tool offsets
Origin should be at bottom left, or near left when looking at the machine.
Not a rule, but most are set that way.
17 Sep 2024 12:37 #310305
Thats how I did it on a manual mill and its more repeatable against the fixed vice jaw.
With Fusion 360, it does not matter. I always touch off at top left even though the machine origin is front left.Origin should be at bottom left, or near left when looking at the machine.
- upplib
17 Sep 2024 17:13 #310324
by upplib
Replied by upplib on topic Running Gcode Program with G54 without any tool offsets
Thanks to all. It was my Mistake, There was a G53 Z0 M6 at the top of Gcode File.
after i removed that all was OK.
Time to create page: 0.152 seconds
