[Solved] Linuxcnc crashes on startup after adding spindle config in stepconf
18 Sep 2024 18:10 - 09 Oct 2024 17:00 #310396 by jtupulis
I hav ebuilt printNC machine and now I'm into configuring linuxcnc for it. So far all config is done via stepconf, no ini or hal edits. I have configured all but spindle control. The problem is when I add Spindle PWM on pin 1 in stepconf linuxcnc crashes on startup. Sometimes it crashes linux alltogether.
I'm adding my ini and hal. Also, I'm adding crash report, but I'm not sure if it helps because crash report is different every time.
Please, help me figure it out.
Last edit: 09 Oct 2024 17:00 by jtupulis.
18 Sep 2024 18:15 #310400 by Aciera
error message is missing
18 Sep 2024 18:37 - 18 Sep 2024 18:44 #310403 by jtupulis
Sorry, there will be no crash report today. I lost the file and can' t produce a new one because linuxcnc is crushing linux every time since. I tried like 10 times. Will try later again. But I'd put no hopes on the crush file, because, as I said, it is different every time I was able to see one.
Last edit: 18 Sep 2024 18:44 by jtupulis.
18 Sep 2024 19:07 #310408 by jtupulis
I got the report file finally.
  • Moderator
  • Moderator
19 Sep 2024 14:16 #310455 by tommylight
This seems more of a PC issue as there are "seg fault" and "corruption" errors all over the log, or might be the RTAI kernel really, really does not like that PC.
If you do have another PC (even with no parallel port), yank the hard drive out and put it in the other PC and see if it boots and runs some SIM configs included with LinuxCNC.
The following user(s) said Thank You: jtupulis
24 Sep 2024 12:03 #310700 by jtupulis
Thanks for the reply!
That was my suspicion/worry too. I'll look for another PC.
09 Oct 2024 17:00 #311660 by jtupulis
Just an update. Yes, another PC performs ok.
Time to create page: 0.138 seconds
