- LinuxCNC
- General LinuxCNC Questions
- [Solved] Linuxcnc crashes on startup after adding spindle config in stepconf
- jtupulis
18 Sep 2024 18:10 - 09 Oct 2024 17:00 #310396
by jtupulis
[Solved] Linuxcnc crashes on startup after adding spindle config in stepconf was created by jtupulis
I hav ebuilt printNC machine and now I'm into configuring linuxcnc for it. So far all config is done via stepconf, no ini or hal edits. I have configured all but spindle control. The problem is when I add Spindle PWM on pin 1 in stepconf linuxcnc crashes on startup. Sometimes it crashes linux alltogether.
I'm adding my ini and hal. Also, I'm adding crash report, but I'm not sure if it helps because crash report is different every time.
Please, help me figure it out.
Last edit: 09 Oct 2024 17:00 by jtupulis.
- Thank you received: 2176
18 Sep 2024 18:15 #310400
Replied by Aciera on topic [Solved] Linuxcnc crashes on startup after adding spindle config in stepconf
error message is missing
- jtupulis
18 Sep 2024 18:37 - 18 Sep 2024 18:44 #310403
by jtupulis
Replied by jtupulis on topic [Solved] Linuxcnc crashes on startup after adding spindle config in stepconf
Sorry, there will be no crash report today. I lost the file and can' t produce a new one because linuxcnc is crushing linux every time since. I tried like 10 times. Will try later again. But I'd put no hopes on the crush file, because, as I said, it is different every time I was able to see one.
Last edit: 18 Sep 2024 18:44 by jtupulis.
- jtupulis
18 Sep 2024 19:07 #310408
by jtupulis
I got the report file finally.
- Thank you received: 7488
19 Sep 2024 14:16 #310455
Replied by tommylight on topic [Solved] Linuxcnc crashes on startup after adding spindle config in stepconf
This seems more of a PC issue as there are "seg fault" and "corruption" errors all over the log, or might be the RTAI kernel really, really does not like that PC.
If you do have another PC (even with no parallel port), yank the hard drive out and put it in the other PC and see if it boots and runs some SIM configs included with LinuxCNC.
The following user(s) said Thank You: jtupulis
- jtupulis
24 Sep 2024 12:03 #310700
by jtupulis
Thanks for the reply!
That was my suspicion/worry too. I'll look for another PC.
- jtupulis
09 Oct 2024 17:00 #311660
by jtupulis
Just an update. Yes, another PC performs ok.
- LinuxCNC
Time to create page: 0.184 seconds
