Control Can bus
- TheRoslyak
- Thank you received: 37
23 Sep 2024 09:32 - 23 Sep 2024 09:43 #310632
by TheRoslyak
Control Can bus was created by TheRoslyak
Could you suggest if there is a solution for controlling LinuxCNC drives and other devices via standard CAN? Has anyone worked on such a task?
I understand that there is the EL6751 block, which controls CANopen. But I haven't delved deeply into whether there is a fundamental difference and how to configure it for regular CAN. Is this possible? Does anyone have experience with this?
Last edit: 23 Sep 2024 09:43 by TheRoslyak.
- Benb
- Thank you received: 61
24 Sep 2024 00:04 #310674
by Benb
Replied by Benb on topic Control Can bus
This might help
forum.linuxcnc.org/24-hal-components/418...can-bus-ethercat-etc
github.com/dbraun1981/hal-cia402
