Decent servo suppliers and recommendations
- bentiggin
- Thank you received: 7
28 Sep 2024 00:52 #310930
by bentiggin
Decent servo suppliers and recommendations was created by bentiggin
I'm looking for a small servo motor and drive combo and I'm just not having much luck.
I think I sold myself on yaskawa, but the few companies I've reached out to either will get back to me with a quote(it's friday, i get it) or haven't been helpful. I asked one company about driver dimensions and was told to google it...
So I figured I'd see if anybody had any opinions or suggestions.
I've heard the ebay seller industrialpartsshop is a good source but I'm nervous about pairing the correct motors and drives, since they sell them separate, although I haven't asked to see if they'll help with that yet.
I would definitely consider other brands, but yaskawa and delta seem like the best choices to me. I wouldn't mind paying a little more to a company that doesn't mind answering a few questions or is based in the us.
My mesa card sends analog signals so I like the idea of getting analog compatible drives. I know that step/dir and ethercat are possibilities, but I don't know any reasons why I shouldn't stick with analog.
- ihavenofish
- Thank you received: 286
28 Sep 2024 02:14 #310936
by ihavenofish
Replied by ihavenofish on topic Decent servo suppliers and recommendations
Delta is easily found for very cheap online and has a good reputation. Hard to beat for value from a top end supplier.
Lichuan makes some lower priced kits people are trying out (ethercat as well as step/dir). I have not seen any on an actual linuxcnc machine running yet though.
- Thank you received: 7488
28 Sep 2024 02:35 #310938
Replied by tommylight on topic Decent servo suppliers and recommendations
forum.linuxcnc.org/ethercat/51830-marco-...utube-about-ethercat
- ihavenofish
28 Sep 2024 02:38 #310939
by ihavenofish
That's leadshine. A potential option here, but their prices are way too high.
- pippin88
- Thank you received: 51
28 Sep 2024 02:41 #310940
by pippin88
Replied by pippin88 on topic Decent servo suppliers and recommendations
Yaskawa will be $$$
Buy matched motor sets
Do not bother buying separate motor and driver and trying to match them
I am happy enough with Delta for the price point. They have decent manual however still easy enough to find bits that are not clear. Delta tuning software is OK.
Modern servos are very complex and configurable when you get into the nitty gritty.
Lichuan cheaper but documentation poor.
- Unlogic
- Thank you received: 128
28 Sep 2024 04:33 #310943
by Unlogic
Replied by Unlogic on topic Decent servo suppliers and recommendations
I can also recommend Delta, I'm using their servos for all axis and the spindle with very good results. Purchased them from AliExpress. All the documentation and utilities for them are available on the Delta website. The manual is over 1200 pages.Delta is easily found for very cheap online and has a good reputation. Hard to beat for value from a top end supplier.
28 Sep 2024 09:57 #310957
Yeah, sorry for that, lack of sleep as usuall and shooting from the hip.That's leadshine. A potential option here, but their prices are way too high.
28 Sep 2024 10:04 #310959
Replied by andypugh on topic Decent servo suppliers and recommendations
DMM?
www.dmm-tech.com
I seem to recall that there was an issue with their analogue voltage control on the Dyn3 drive (I have never actually used them)
But I think that they are familiar enough with LinuxCNC to be able to advise if you contact them (they are in Canada)
www.dmm-tech.com
- pippin88
28 Sep 2024 10:28 #310966
by pippin88
DMM
Vague memory that analog is an issue due to delay in output of the encoder signals from the drive. So closing the loop in LinuxCNC was not workable because it was too slow / delayed
(step/dir not an issue as the loop closed within the drive and there was no delay issue there)
- pippin88
28 Sep 2024 10:32 #310968
by pippin88
For a new servo setup, I would go ethercat servos.
Sell the Mesa board (there is plenty of demand for Mesa).
I would only buy servos with software available for setting parameters and tuning.
Setting multiple parameters with the few buttons on the drive is awful.
Time to create page: 0.253 seconds
