Help me decide. To Retrofit or not to Retrofit.......
30 Sep 2024 23:11 #311099 by ConSonar
Machine -
1993 Fadal VM15XT
Geneva style tool changer
7500rpm spindle (that's done with a 10volt signal) also easy FWD and Reverse connections
I already have Mesa 7i96s and a 7i85s. I'd want to run stepper online 1000watt servos possibly even the ethercat versions, but the 7i96s I have would run the step/pulse version just fine. Might have to snag another mesa car for some inputs, but the Fadal is a simple machine. Air operated spindle orientation, simple operation of the tool changer. I like the idea of absolute encoders as I could treat it kinda like the original control that used resolvers and simply call the old cold start my "home".
The reason I'm thinking about this is I need to replace the Y axis servo motor for a cool ~$1700. Instead op throwing $1700 at older tech, I can spend about that getting everything else that I need. Only down side is I would have some down time while setting up LinuxCNC.
Once I get the bugs out of the linux install, I'd imagine if I could control myself from tinkering with it, it would just run like its supposed to. So do you think its worth it or not? I have about $20k of work for the machine in the next 8-10months. Being down right now is not a HUGE issue, but I have a solid month / two months or so before it needs to be able to make parts again.
Also I could sell stock axis amps along with amp cards and such and cover more than it would cost me to retrofit the machine.
  • Moderator
  • Moderator
30 Sep 2024 23:29 #311100 by tommylight
I have retrofitted fully functional machines (3 from a quick recall), so i am biased! :)
30 Sep 2024 23:36 #311101 by ConSonar
I know its not going to be as easy as replacing the servo motor, but it SHOULD be more rewarding in the fact that I will not be depending on 30 year old hardware that may or may not get me for 300/600/1800 at a time lol
30 Sep 2024 23:38 #311102 by ConSonar
To be honest the only thing that has me concerned is writing the logic for the tool change.
I know what needs to be done and the steps, but I do not know anything about classic ladder or programming so that will be some learning on its own.
30 Sep 2024 23:41 #311103 by andypugh
I like resolvers. Both my machines use resolvers, Mesa do a card that can handle them, and drives that can use that feedback to drive the servos (if they are brushless, I suspect your existing ones are probably brushed, though?)
I agree that $1700 for an old (used?) servo might not be a good investment, though there is a counter-argument that in 1993 this was a very expensive machine and the original servos are probably very high quality. (not much comfort having a broken high-quality servo, admittedly)
01 Oct 2024 00:28 #311105 by ConSonar
That's a price for new servo. DC Brushed machine. I like the old fadals cause you can get parts for almost everything. I just don't wanna have to buy this one lol.
01 Oct 2024 04:35 #311110 by spumco
Glentek GM4050 (MTR-002) runs about $300 to $800 on ebay.
I have some thoughts/suggestions on a possible retrofit if you're interested.  Little late tonight, but if you're interested let me know.
The following user(s) said Thank You: ConSonar
01 Oct 2024 21:54 #311131 by ConSonar
A lot of those GM4050s are not the -38 that I need. 4050-38. I did find a few for ~$800.
What are your ideas on retrofit...Im all ears.
02 Oct 2024 02:50 #311139 by spumco
Sorry if I gave you bunk ebay info - the usual Fadal spare parts manual didn't specify a "-38" sub-model.
Ok, so retrofit thoughts...
Do you have any experience operating a machine under LCNC?  If so, no issues on that front.
If not, then along with all the retrofit stuff you'll have to learn how to write programs and operate LCNC.  I love LCNC, but it's NOT Fanuc (or Fadal 88), and there is a learning curve. Little things - like single-block - are different, as are some big things (Macro B, GOTO, etc).
There are a number of people on the forum who have demonstrated a successful Fadal retrofit (including a recent one using Probe Basic).  But I suspect it took them more than the  "month or two" you indicated you have.
Those stepperonline servos ( I have some T6's) are decent, but the programming/tuning software is a miserable hack of Leadshine's OEM version.  And Leadshine's version doesn't work any better on the Stepperonline drives.
Torque:
T6-1000W - 3.19nm (9.56nm peak)
GM4050-38 - 4.67nm (23.35nm peak)
So they're way down on torque from the Glentek's.
Along with fighting the software, those servos will require an adapter plate and a different coupling at minimum.  Not a big deal for someone with a working mill, but not easy to accomplish without one.
For a hobby situation, I'd say go for it.  But for a working shop, I'd suggest being a bit more... conservative.
I'd buy a used servo and fix the Fadal, and also the parts needed to get LCNC working on the Fadal.  Then, while the mill is making parts, put together a working benchtop configuration of LCNC with all the I/O mocked up.  That includes choosing a GUI, building a new operator panel, as well as a mocked-up ATC.
You can 3D print a geneva mechanism and get a cheapo DC motor, along with some $10 mini air cylinders, and have a working model of the ATC to drive around while you sort out all the LCNC programming & config.
The operator panel you have could be hacked up, but it's worth more intact to somone else.  Use the 'pre-rebuild' time to fabricate a decent panel with physical inputs & MPG.
You can take your time, run some programs, even run the 'toolchanger' - about the only thing left will be tune the servos against the actual loads.
Get it all sorted out and only then take the mill out of service and do the retrofit.
As far as the ATC goes, there are a number of ways to skin that cat.  Probe Basic has built-in ATC subroutines and it's pretty easy to connect to your existing geneva drive.  Andy Pugh's recent edits of carousel.comp are also great, and there are plenty of examples on the forum of working ATC's.
Just my two cents.
The following user(s) said Thank You: tommylight, timo, ConSonar
  • Moderator
  • Moderator
02 Oct 2024 03:30 #311143 by tommylight
Just went back on this, my reply is a bit lacking so i am blaming it on lack of sleep as usual (5:28AM here).
I have retrofitted probably over 10 machines, 3 of those were fully functional with factory controls, so i yanked those out promptly and put Mesa boards all over them.
Time to create page: 0.179 seconds
