radius to end of arc error.
- ARCANGELWELDINGMT
05 Oct 2024 21:26 #311369
by ARCANGELWELDINGMT
radius to end of arc error. was created by ARCANGELWELDINGMT
Hello, all I have suddenly been getting numerous errors when trying to run my table. I have tried all the fixes on radius to end of arc errors. I have a suspicion that the recent fusion update may be causing this. I reprocessed an old file I had, and it now also won't cut. is anyone else having issues.
- Thank you received: 7488
05 Oct 2024 23:12 #311375
Replied by tommylight on topic radius to end of arc error.
More info....?
The following user(s) said Thank You: ARCANGELWELDINGMT
- ARCANGELWELDINGMT
06 Oct 2024 01:29 #311381
Replied by ARCANGELWELDINGMT on topic radius to end of arc error.
Sorry for the lack of information. my brain went squirrel. so suddenly I don't have any material selection on line 18 of and geode made with fusion. I also have the radius to end of arc differs from radius to start. errors on all the arcs and curves. ill attach a code file that i processed this afternoon. I had no problem making usable code on Tuesday but now i am not having any luck.
. I have not run back to the shop to get my config files downloaded. I don't feel it is a change on the control computer since it is a stand-alone that was working well as of Tuesday.
- ARCANGELWELDINGMT
06 Oct 2024 01:43 #311383
I guess I can't attach a copy of my post processor. it is PlasmacV2.1 I don't know if that matters. I have muddled through most of the issues that I have had come up by YouTube and the forum.
- phillc54
- Thank you received: 2100
06 Oct 2024 03:16 #311384
by phillc54
Replied by phillc54 on topic radius to end of arc error.
I can load that ngc file in both PlasmaC and QtPlasmaC with no issues.
I see that the PP adds both G90 and G9 to the preamble which are the LinuxCNC defaults.
Could you take a screenshot of the error message so we can see the incorrect values.
- ARCANGELWELDINGMT
06 Oct 2024 04:09 #311385
ok I went and got my ini file and took a picture of the error message. and will add the file that was with the error message this time around. I may have a setting buggered. it has worked for what I have tried before but I am relatively new at this.
- ARCANGELWELDINGMT
06 Oct 2024 04:20 - 06 Oct 2024 04:27 #311386
my 1.3 mb pic won't upload
operation error:
g code error in treecandle3.ngc
near line 152 of
/tmp/emcflt-tuxqhmgh.d/treescandle3.ngc
radius to end of arc differs from radius to start:
start = (x11.5745.y3.2479) center= (x11.5902.y3.2604)
end = (x11.6001.y3.2834) r1=0.0200 r2=0.0250
abs_err=005033 rel_err=20.1065%
operation error:
near line 152 of
Last edit: 06 Oct 2024 04:27 by ARCANGELWELDINGMT. Reason: upload wont fit
- ARCANGELWELDINGMT
06 Oct 2024 20:28 #311439
well I turned off merge circle and made a useable code.
